I know they are not well thought of, but I would like to retro fit if possible...but is it ?
They're crap
![]() If you have the plain button, retrofit the newer, round metal button.
I wish I could bloody get mine to work!
On cars with it fitted as standard, there is no memory seat buttons for the driver. That means, I can't set a preset for my preferred seating position or anything. Grrr... |
Yes you can. You need to activate the menu so the key moves the seat and mirrors when you open the door.
Del ![]() |
It's a bit of a gimmick really - cool to tell people you have it but if it was a good idea the other manufacturers would have done the same back in 2003/2004 I say. I think I used it once when I picked the car up, programmed my finger but it changed the mileage to km, all the radio settings and adjusted everything possible to do with the seat so I didn't bother using it after that
![]() +1 for retrofitting the facelift chrome Start button
Currently '8-less Previously: - Aqua Blue Pearl D3 S8 - Kamut Beige leather, ACC, B&O, factory RSE, solar sunroof, electric blinds, ski bag, Homelink, comfort headrests. - Aqua Blue D2 S8 - Grey leather/Alcantara - D3 A8 3.0 CVT - D3 3.7 V8 |
![]() Sorry, didn't mean to hijack the thread, but it's vaguely on topic. |
In the end I had the battery disconnected for 30 mins for something else, and if by magic the fingerprint system started working properly again so i'd give that a go if I were you.
Del ![]() |
Thanks Del. Tried that - my battery is only too keen to oblige by going flat. It didn't work.
I un-coded the module, re-coded the module, changed the switch, you name it. |
If you'r a masochist go ahead and retro fit the fingerprint start button. I'd be happy to see the back of mine and its irritating negative message almost EVERY time I fire it up
A journey of a thousand+ (epic) miles, begins with a single step, (to the door of an 8). Lau Tzu |
My D3 gets little use these days, and after a week or so of short trips the battery on mine gets low, and I usually end up using the key remote and ignition to start the car until I go for a long run to charge the battery back up. There are issues having the memories tied to fingers, for example if one driver is short and the other tall then shoe horning yourself behind the steering wheel and hitting the start button could be difficult, before the seat moves back to your usual position. If setting up having got the car remember to delete all the programmed users before you begin otherwise you simply end up with their settings for everything. Remember its not just the seat position set by your finger, the climate control settings, radio presets, last station, satnav destinations, steering wheel, mirrior positions etc. are all individual.
