just had the dreaded PRNDS for the first time ever ; living at altitude in southern france we still get warm sunny days at this time of year , but it means temperatures around zero overnight due to the clear blue skies ...and as I was out early in the morning I left the car out
as it happens the car is going to the local garage to check the differential levels on monday in case there is a seepage , so having a look at the 125 and cleaning the connection seems logical but as it will be up on the ramp it occurred to me that it might be sensible to have the fluid level in the transmission checked , not that there seems to be a problem but who knows ? rebuilt transmission 25k ago from the audi agent so is there any knack to this to tell my F*** trained mechanic ? ~I keep reading about correct temperatures and oil overflowing ? suffice it to say that when I was at the audi agent yesterday [ was down to 1 key so had Ebays cut and went to have the set coded ....standard price in france to do the set €51 I was told ] I invested in a litre of ATF , €20 ; I liked the fact that the parts man wouldn't sell me anything until he checked against the VIN |
Yes, there is a specific procedure. You need to start from cold so it'll have to stay there overnight for them to check the following morning. The temperatute has to be checked with VCDS. You also need a special filling tool as you have to pump the oil in from underneath. I use this:
![]() With the engine running, watch the gear oil temperature in VCDS until it's at 30-35*C, then remove the large filling plug in the sump (17mm hex, not the small 6mm drain plug). Pump in oil until it overflows and wait for it to stop dripping, then put the plug back in. The oil temp mustn't go above 40* while filling. It'll cool down slightly as you add fresh oil. Tbh if it was rebuilt only 25K ago and there are no visible leaks I'd be inclined to leave it alone for now and just check the F125. |
See the attached ZF Spare Parts Catalogue - page 4/5 has the step by step for the filling procedure.
Don't forget you need to run it through the gears to ensure the transmission is full of oil Mikki!
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
