Old 21st January 2009, 12:57 PM
A8 Doc A8 Doc is offline
Default Parking Brake Fault
Symptom - Parking failure on centre display and loud beep whilst driving. If scanning with VAGCOM there will be no voltage from one of the calipers.
[b]Resolution[b] - New brake caliper required complete and possibly new parking controller. Will require coding on reinstall.
Old 3rd December 2010, 06:15 AM
hans
Guest
Posts: n/a
Default same problem
I have exactly same problem but with the abs sensor light on together. Has been going back so manytimes to the dealer but the problem is exist... frustrated need advise
Old 13th December 2010, 04:27 PM
Failed parking motor most likely. It will be unable to see the right or left supply channel voltage.
Otherwise parking ECU.
Old 28th December 2010, 03:01 PM
Ensure you have the latest software on the module or replace the module. Worke for me.
Old 13th September 2011, 09:09 AM
sutherland sutherland is offline
How do you establish if it is the caliper or the ECM? Is swapping around the calipers for testing a possibility, or even simply plugging in the working caliper to the other side?
My local garage tested for voltage going to the connector, but nothing showed up even on the side that is working.
Old 13th September 2011, 10:11 AM
Does the caliper move in and out with the motor?
Can you plug VCDS in and perform the tests?
Old 13th September 2011, 05:59 PM
Is the ECM attached to the caliper? I thought it was in the boot.
The caliper does not move and the motor does nothing. VCDS reports:
Tuesday,13,September,2011,18:58:29:15869
VCDS Version: Release 10.6.4 (x64)
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Control Module Part Number: 4E0 910 801 A HW: 4E0 907 801
Component and/or Version: EPB AV1C1010 H01 1010
Software Coding: 0000331
Work Shop Code: WSC 00443 210 91502
VCID: 1D3AD94ABD21
Fault Codes have been Erased
1 Fault Found:
02433 - Supply Voltage for Right Parking Brake Motor (V283)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 1
Fault Frequency: 27
Freeze Frame:
Voltage: 10.35 V
Count: 87
Thanks
Old 13th September 2011, 09:06 PM
Stupid question.. have you taken the power connector off and cleaned it? I had this a few winters ago, wasn't quite on properly so some crap had gotten in.. Some wd40 and emery paper and it's been good since.
Though it could be dead
Old 14th September 2011, 12:58 PM
You can hope!!
If it was me... I would remove your battery and locate the ECM in the boot. Then test the wiring (Use the colours) and do a continuity test from the caliper to the main wiring loom to the ECU. Rule that out first.
Easy to do with a paperclip and an electrical testing meter.
Old 26th March 2013, 06:14 PM
a8starr a8starr is offline
Hi Guys
I am new to the forum. I just bought the VCDS package and scanned my car. I also got the parking brake fault but the warning light only comes on sometimes and the disappears after I flick the parking brake up and down a few times.
