Old 28th December 2016, 09:53 AM
clubadria clubadria is offline
Default Headlight bulb
Hi
This may seem like a daft question, but what is the headlamp bulb number for the dipped beam, most common is H7/H4 but aren't these lights bi- xenon.
My lights have the cornering feature not sure if helps at all.
The N/S has a light blue colour which I don't like, the O/S has a new headlamp not sure about the bulbs as garage fitted this.
I hope that I've given someone the info that could tell me.
I could of course take the bulb out, but its cold and I have a very long list of jobs on this car before I can go spending money on such luxuries.
Thanks
David
Old 28th December 2016, 12:54 PM
homer simpson's Avatar
I believe if they are Xenon then you need D2S
Check here, it's fairly accurate
http://www.autobulbsdirect.co.uk/
Old 28th December 2016, 03:45 PM
Thanks for the link
Just looked and there's loads to choose from.
Which do most people use.
Thanks
Old 28th December 2016, 04:24 PM
I bought these...
http://www.autobulbsdirect.co.uk/D2S...-HID-Bulb.html
They work fine, but not worth the extra money as I can't really see any difference in brightness or whiteness over stock, I hoped they would be as white and bright as new cars with HIDs. I got them from Amazon (amazon themselves not a marketplace seller)
https://www.amazon.co.uk/XENARC-INTE...=66240CBI&th=1
Old 28th December 2016, 05:28 PM
Thanks for your help.
Will keep these in mind when I get through some of the other work.
Front suspension first job.
update mmi buy vcds cable as well.
N/S rear door not working keyless everything else works.
replace led strips on the n/s.
Then work on the faults.
