Old 5th February 2017, 01:42 PM
Yeah I have. I used the black pan-head torx screws that are used to hold the arch liners so they are almost invisible at a glance. I'll grab a pic this afternoon
Old 5th February 2017, 06:01 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
A couple of pan head stainless steel self tappers hold on to mine
ID:	15564   Click image for larger version
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 5th February 2017, 06:39 PM
Mine is exactly the same but with black screws
Old 6th February 2017, 07:10 AM
barzya8 barzya8 is offline
Thanks guys & girls
Guildford, Surrey
Bose sound system.
Audi Navigation Plus.
20 inch Final Edition alloys
Old 6th February 2017, 01:00 PM
To save me crawling around and feeling the materials and behind, what's a good size and length to go through both layers and grip well without hitting anything it shouldn't?
Old 6th February 2017, 01:12 PM
10-15mm. There's plenty of space behind that surface. It only needs a small self-tapping screw - 4mm or so is fine.
Old 6th February 2017, 01:16 PM
Thanks.
The only suitable screws I have on hand are fairly short at 10mm thread so I'll give them a go first.
Old 16th February 2017, 11:31 AM
Job done, black 10mm screws both sides, nice and tight.
Old 16th February 2017, 01:32 PM
I think mine are drilled as per Oli18's original thread, and then cable tied with black cable ties, but I've also got the earlier 2 part grilles on each side so double the amount to fix *sigh*
Old 16th February 2017, 04:53 PM
I'm actually tempted to "double up" with screws bottom as well as top, or maybe outer as well as inner.
