Old 8th February 2017, 08:47 PM
47p2's Avatar
47p2 47p2 is offline
I've been using them for years, the quality of the welds are a thing of beauty. You'll be well chuffed with the finished article
Nite Blue 3.0L SE Quattro
Old 8th February 2017, 09:01 PM
YorkshireBloke's Avatar
Default What a Forum...
Old 9th February 2017, 08:24 AM
Trouble is that I will probably now feel that I want the whole exhaust done when I take it in!!
Just about to go and collect the car (courtesy of BrianG who is acting as my taxi at the mo ) Just waiting to hear the rumble of his RS6 outside my door now.
He has just turned up in his Fiat Stylo .......
Old 9th February 2017, 09:00 AM
Should've specified your preferred choice of vehicle when you made the booking
(Black, with all black premium interior and carbon fibre dιcor, 21" sonic carbon twin turbine wheels and FSD capability)
Old 9th February 2017, 10:00 AM
The news is less good on my D2 - the MOT is sorted ok and new washer motor, track rod end and some fettling with the brake wiring to stop an intermittent brake warning light is done, but unbelievably the F125 switch on my gearbox has had to be replaced due to one of the internal components corroding and breaking off, and as this was one of the contacts it meant that the F125 was inhibiting starting of the car and throwing up warnings or not sending correct messages to the auto box, so it has had to be changed
I'm really quite annoyed about this as the box has barely done 25,000 miles from being changed and I'm also told the rear output seal is starting to dribble which means another job to change that shortly too. Is that really acceptable on a box with that low mileage from new? I know it is probably 5 years since changing it but geez surely there has to be some better longevity in a new box from Audi than that? Yours. . . . disgruntled in swindon
ID:	15616   Click image for larger version
Old 9th February 2017, 02:15 PM
I feel your pain after mine failed last year.
Its a cr@pp, flimsy piece of electromechanical equipment which really should have been re-designed/re-engineered a long time ago.
"Made in Spain" it says on the box for my replacement.
Old 9th February 2017, 03:05 PM
Wow that's really poor after such little mileage
Old 9th February 2017, 03:10 PM
On a brand new transmission? that is really bad.
And the leaking rear seal too, I remember on my D2 it kept re-leaking until I got the whole new re-designed flange and new seal, but I sold it not long after that so I don't know how well the new flange held up.
For Cats I can only reccommend HJS cats from Germany, had them for over 3 years on the previous D2 sailed through emissions every time, never corroded. I now have the same cats on the current car too. They are pricey at around £350 per cat, but in this case I think the lifetime warranty is iron-clad (pun intended).
In other words the Germans build so well you won't have to use the warranty
Old 9th February 2017, 03:15 PM
Presumably the new gearbox had the original design flange and seal, in which case the leak is about due. My first D2 had one at 2 years old.
Old 9th February 2017, 03:22 PM
I've gone with C+C Custom Stainless Exhausts nr Glasgow. They have some good recommends and come out at around £525 for the pair in 304/316 grade S/steel - with warranty.
