Old 18th February 2017, 06:56 PM
Default Ooops
So..... I took the air boxes out to clean the MAF sensors and whilst there remove the lower section to check the power steering fluid level. Lucky I did as it was below min level.
Anyway, mid way through the task, pulled too hard on the air box and snapped the sound valve thingy off!!!! Anyway, it came off so cleanly I managed to bond it back on with no issues.
Be careful!
Old 18th February 2017, 11:03 PM
Turbo Tony's Avatar
You're not alone there, buddy. Add a little contact adhesive and it sticks right back on.
Storytellers Villa Orlando
2008 Audi S8
Old 19th February 2017, 09:58 AM
daandaman daandaman is offline
Or leave it all off, cut off the boss and use a big black heat shrink tube with adhesive inner coating.
