Old 15th July 2017, 12:40 PM
erubus erubus is offline
Default Think I've got a leaking strut
The last two mornings that Ive driven to work the yellow warning lamp on the dash for the suspension has been lit for the first half mile or so. Ive stuck it from dynamic to comfort and the light has gone out on both occasions and has only returned the next morning.
I haven't used the car since thursday night and it looks like its sitting much lower than usual at the front now although it doesn't seem to have changed since yesterday. There is about an inch between the top of the tyre and the wheel arch (18" wheels). I'm not sure if this is it sitting on its bump stops or if it will get lower yet. I'm not planning on using it again until tuesday morning so I will see if it drops any more i that time.
What exactly is the processs for leak detection on the airbags? Does lifting the car up to its max height using the "lift" option on the MMI suffice or is the jacking mode that I've seen referred to consist of a further height adjustment that is only available with VCDS? I presume that the dust covers just come off the strut and you can easily get in about the airbag with leak detector spray and it will all be very obvious. Do you do this with the wheels on or off?
Also, how do i know when the compressor is running and how often should it run normally? The compressor runs silently so I have no idea how much it runs to maintain the ride height. Does the up arrow on the suspension screen on the MMI go solid whenever the compressor is running for instance?
Obviously I want to get this sorted ASAP before the compressor or relay end up getting burnt out, so as usual, any and all help will be gratefully recieved.
Gill
Old 16th July 2017, 04:19 AM
27litres's Avatar
27litres 27litres is offline
If it turns out you do have a leak, FCP Euro have the Arnotts front struts going cheap in their 'clearance' section.
I can send you a link if you like.
As for Arnotts airbags, some like them, some don't. On Allroads, they seem to perform very well, but I've read mixed reviews on D3's. So you can seek opinions on here before buying if you like.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 16th July 2017, 07:08 PM
thanks for the heads up. I had a look on their website but couldn't find the struts.
I had a bit of a read up through the suspension section on here and have done some measuring. All measurements are from the ground to the bottom of the wheel arch in th centre.
NSF 660mm (this is the one I suspect has a leak)
OSF 698mm
NSR 706mm
OSR 708mm
Then I started the car. The orange warning light was lit on the dash again. It seemed to take ages to go off but the car did eventually lift. After it had settled the measurements were:
NSF 684mm
OSF 724mm
NSR 694mm
OSR 696mm
Then I put it into lift and set it to jacking mode:
NSF 720mm
OSF 760mm
NSR 739mm
OSR 740mm
So, the rear wheels are within a mm or so of eachother in any mode, the front ones differ by 40mm in every mode (40mm lower on the NS) The NS tyre looks to be pretty soft and the drive isn't exactly level so this could easily account for the difference side to side. Now that it is set to jacking mode I should be able to narrow down any leak to an airbag and pipework up to the valve block and should know more. I really need to get someone with VCDS to have some time on this car. I can get the compressor output checked and have a look at the engine as well on startup and hopefully get a better idea of the hot start problem.
gill
Old 16th July 2017, 11:20 PM
27litres's Avatar
Here's what I found in the clearance section:
audi-air-shock-arnott-4E0616040AA
If the picture is accurate it might be the rear airbag?
I don't know what the strut connections look like on a D3...
So check the part number...
Edit:
Just checked ETKA and that part number checks out for a right hand front strut. Right and left are different it seems...
4E0616039AA (and numerous other suffixes) left
4E0616040AA (ditto) right
"For Sports Suspension"
Near side = left, yes? If so you'll find it, but not under clearance!
left strut
right strut
Looks like their "clearance" price isn't all that special...
Check against what our forum sponsors have too.
Marty
Family:
Sold:
1997 Audi A4
Old 17th July 2017, 10:08 AM
Thanks for the sleuthing. I think you're right in that the left and right struts are different. I had a look on flea-bay. There are struts (used) for pretty reasonable money, circa £100. I'm starting to think along the lines of getting a newer A8 with the 4.2 tdi. The ticking from the engine annoys me but the thought of stripping the whole engine out and paying hundreds for parts to fix it isn't too appealing. If I'm not keeping the car long term I'm happy to spend less on a used part than forking out for new.
Measurements from this morning for the suspension. NSF exactly the same as yesterday, all the other ones seem to have risen by 5mm. Given the car is in jacking mode they shouldn't have changed at all by my reckoning. Perhaps its the difference in temperature. It was 14 degrees yesterday and 18 today in the sun. cant imagine that small difference changing the height though.
I'm not sure that this proves anything at any rate. I'm going to start running the car in comfort mode and see if it still puts the warning light on the dash every morning. I've always thoght that it looks ridiculously high in comfort mode though, hence why I always run it in dynamic. Still, in the interests of a diagnosis i will put up with it.
gill
Old 22nd July 2017, 11:30 AM
Wee update. Ive been running the car in crop sprayer mode for the last weekor so and havent had the yellow warning light back on since. Since the car didnt drop when in jacking mode and doesnt appear to be dropping in comfort I am assuming that there is some cracking on the where the airbag curls back in on itself when its set to dynamic. when the car is sitting higher the crack are getting closed up and are no longer leaking.
I'm going to go back to running it in dynamic and see if the problem returns. That should narrow it down to one of the airbags (I think) If you put the car into jacking mode when its set to dynamic, does it still lift the car up to the lift position or will it lock up the valves in the lower position?
gill
