Old 16th July 2017, 08:15 PM
Default new knob
it all bolted together nicely. i made some temporary adjustable gearbox mounts so i could adjust the box position up/down /left/right from under the car. lengthened the linkage 90mm
ID:	16535   Click image for larger version
ID:	16536   Click image for larger version
ID:	16537   Click image for larger version
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 16th July 2017, 08:33 PM
Default new knob
so the gear knob does fit but you have to change a few parts. And I've still finish my driveshafts, prop, clutch pedal, ecu. its all doable but it just takes time. Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 16th July 2017, 08:41 PM
Phew! Glad you got the knob to fit properly in the end - otherwise it would have been a complete waste of money
Good effort and
Old 16th July 2017, 08:42 PM
Default new knob
Hi MikkiJayne yes all on my own. mike said you had started yours I've still plenty todo I'm just working through everything as i get to it. Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 16th July 2017, 09:25 PM
No RHD manual D2s for 22 years and then two come along at once
Interesting to see that the B/C chassis shifter setup fits in the D2 body. The factory D2 shifter is characteristically arcane and higgledy piggledy for no apparent reason.
It'll be interesting to compare notes when we're both finished
Is that the Avus Silver (and Red!) FE I "assisted" with as "procurement adviser"?
Yes
Old 16th July 2017, 11:15 PM
Johnmed's Avatar
Johnmed Johnmed is offline
You folks make this stuff look easy!
2007 Mini Cooper S R56
Old 17th July 2017, 11:29 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Nice use of a hand pallet truck!
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 17th July 2017, 06:50 PM
Default new knob
The pump truck is mikes idea from his engine removal thread. After getting the car up on the ramp and looking at the bellhousing bolts and starter motor.
it would be a nightmare just removing the gearbox. when the car was assembled at the factory the engine and box go in together. it really was very easy to remove the front of the car disconnect, everything and just wheel it out. most things are easy to get at, no seized bolts! beautifully designed and engineered and a joy to work on. i did have access to full workshop with ramp, gearbox jacks,engine crane and mechanic mate.
But i chose to just do it outside in the sun on my own, all i needed was trolly jack, axle stands, pump truck, ratchet strap, and some blocks of wood and a few tools. It was very easy and most people could do it at home on there drive. its all made to be assembled quickly and efficiently.
with a few adjustable legs welded onto the pump truck or a frame!
instead of the timbers i used, installation would be even easier keeping it at the correct angle so the subframe bolts are easy to put in.
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 18th July 2017, 05:29 AM
27litres's Avatar
27litres 27litres is offline
What did you do for your pedal set up and master cylinder to get the clutch working?
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 19th July 2017, 03:44 PM
How did I miss this thread????
Well done Dave!
I hope I get to see the car in person soon.
Please post up more pics of the conversion. If I remember from the audisrs thread the 0A3 doesn't have a speed signal or something, how did you get this to work?
