D3 - Engine Bay Everything under the bonnet |
Dear All,
I recently noticed the P0480 Engine cooling fan 1 malfunction code on my VCDS Hex scan. This seems logical since the AC is a bit warmer when the car is not moving, so missing the fan to cool the condenser. Today I tried the engine output tests for the first time and both the fan 1 and fan 2 operate when I switch these on via the engine output tests - excellent. When I use the Convenience systems AC output tests for cooling fan the cooling fan output is not working and the fan stays off. In the data fields it states N/A for all. Please suggest what I will need to check since both fans actually operate and it looks like a control issue from the AC control system. Apoligies if this issue is challenging, trying my luck hoping someone will know... Thanks again for your help thus far on this wonderfully complicated creature Cheers, Stephen in Scarborough
Present cars Daily driver: BMW e65 730d Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry. ![]() Last edited by Prefferle; 31st July 2017 at 08:30 PM. |
