Old 20th September 2017, 04:39 PM
ulfilias ulfilias is offline
Default Electronic Parking Brake - Left 02432
Hi There,
Got this error code the other day from VCDS, though arguably the whole car shouted about it. Talk about anoying....You need to pull 4 fuses. Two in the boot, two in the drivers side to shut it up!!! Though driving a couple of minutes will cancel the audible alarms until you stop at a junction/lights and it starts again! All for an almost irrelivant parking brake.....I mean park on an Auto makes the EPB all but redundant in most cases!!!
Anyway. Research and it's not an uncommon fault, along with it's brother for the right! It seemed electrical and a connection but lots of wiggling, unclipping and re-clipping and contact cleaner made no difference.
Today i popped the whole unit off the back of the brakes. Two torque screws and unclipping once jacked and the wheel off and the motor unit was clear.
It had a lot of sealant goop over it and some aluminium wrap that is part sealer, part noise reducer it seems. It looked a bit bodgy though. I cleaned the back off and unclipped the back lid and there's a motor with pully belt going to strange toothed wheel / wobbly gear / spline drive.
The strange wheel thing didn't appear to rotate properly, so lots of cleaning, WD, spray chain lube and gentle tapping in a vice to free it off. The belt wheel should rotate on it's tiny bearing (seized) and the wobbly gear spin and wobble. Took a little coaxing, but it slowly made it and after lots of cleaning (isopropyl alcohol) and then lube it's fair and freely mooving.
Gasket sealant on the rim of the back plate and some aluminium tape to cover and close out and some testing and it's all good. I was tempted to epoxy it closed but if it needs servicing again then probably best not. I could be tempted to buy a different car EPB motor (£30-40 vs £300) such as the passat and steal the gear from it
(https://www.audiworld.com/forums/a8-...ailed-2840757/)
Other options are new Motor (£300), Refub Caliper complete (£180+£100 potential refund, 1yr), OEM Caliper (£240, 3Yr) or Audi (£££). Most net searches tend to end up with people going for a Caliper and i'd probably go new as the hasle of sending back and potential refund issues for £60 and less warenty seems daft!
Thought I'd report findings for future use and it may help someone
Lee
Old 26th January 2018, 04:03 PM
Hi There,
Had another issue with this. Error'd a couple of days ago after the day of storms!
Brought it inside and broke things down a bit more thoroughly this time as it was obvious there was water ingress and things silted up.
The motor is two screws to attach, but in removing the brakes as well we found that there would be some form of rubber washer sealing this. It was missing and whomever had used some form of silicone and it had failed and there was a fair bit of aluminium exfoliation (not rust, but white powder) and I think this was the core failure.
Cleaned everything back up and got it all moving and free again and put it back together. Used a gasket sealer as i didn't have the rubber washer and it doesn't fully dry or shrink, so should have better longevity!
And NOTHING.....faults wouldn't clear, added brake pads to the faults and even basic settings at times.
Pulled it in again today and popped the wheel off and just the motor. Connector had power and was doing things. The motor when off the caliper would run.
When putting the brakes back together i had to manually back off the EPB and used a driver in the back of the brake caliper where the motor fits. I wondered if it was up against a hard stop.
I removed the motor, backed this off to a loose mid position (as it was unknown, but neither end) I then fitted the motor back.
I then used VCDS in "open for repair" which worked and then "close after repair" which also worked. Then "Brake Test" and Bingo!!!
Seems the EPB motor was at a limit and as such returning the wrong current / load for what was expected and i'm guessing testing like a broken motor!
Up and running again
Current :
Previous :
Also :
Old 26th January 2018, 08:48 PM
Well done.
As our cars get older, the EPB is becoming more of an Achilles heel.
i have also observed another possible problem - when the piston is not touching the back of the pad, the piston can spin when the motor is operating and when it does, the it's not moving it in or out, I am not sure what is happening on the inside when this happens - and the piston is easy to stop with fingers, but it never reaches the end stop and this also starts to twist the dust seal/boot if it is gripping the piston. Something to watch out for!
Old 30th January 2018, 09:24 PM
Johnmed's Avatar
Johnmed Johnmed is offline
An Achilles heel for sure. I replaced a seized calliper on one side a few years back and have had the EPB’s ECU die. Shame.
2007 Mini Cooper S R56
Old 5th February 2018, 12:28 PM
Wouldn't mind but with the park brake on the engine of an automatic they are pretty superfluous for the most park. Not much use for Handbrake turns either, I mean, HOW are we supposed to impress the ladies now
Current :
Previous :
Also :
Old 5th February 2018, 01:51 PM
Johnmed's Avatar
I thought them largely unnecessary, the pawl brake being sufficient. But they have been known to fail. I use my EPB all the time when I park now.
We are forced now to impress the ladies by being charming, loving, respecting, honouring and listening (my favourite) to them.
Bring back the cheeky handbrake turn and a ‘dab of oppo’ make their knees weak.
Old 26th February 2018, 10:47 AM
So after much testing, dismantling, reassembling, hitting with a hammer, spraying with lube...... both the calliper and motor for my N/S EBC will need replacing. Damn it.
Old 26th February 2018, 11:49 AM
ive bought a few of these from EuroCarParts because I couldnt get them cheaper anywhere but they do hold a deposit against your old ones (unless you take them in when you pick up the new one) and after that is taken into account it wasnt too bad
At the moment if you use a discount code "FEB70" then -
Surcharge(s)* £41.99 (Refundable Deposit)
Subtotal: £576.98
Discount: - £181.90
Total (inc VAT): £395.08
After deposit refund : £353.09
Old 26th February 2018, 12:32 PM
Subtotal: £576.98
Discount: - £181.90
Are the caliper and the electric motor sold as single units or is that the price for both items?
Old 26th February 2018, 08:58 PM
It's the whole thing as an exchange against your old whole thing
Tags
02432, 02433, electronic parking brake, epb
