#61
FST is from an A3...
#62
01E is 830mm total length, 0A3 is 856mm and 5HP24a is 958mm.
On second glance, the 0A3 does have mounting bosses on the side in roughly the same place as the 01E - they're just not used, so you could fabricate mounts to fit the D2 subframe no problem. I presume thats what MRC did when they put one in a B5. That conversion piece for the prop I linked to earlier does not look 128mm long so probably won't work for us. I may email the seller and ask though. Could be we could get a custom batch made up for us if a few people are in. It might work for an 0A3 though, which would be ironic ![]() |
#63
gearboxes.pdf
now i'm confused every time I'm just about to buy a gearbox i check the code numbers and different diff codes come up.again this one says my FBG auto is 3.726 rear axle ratio i'm getting more confused. Dave
2002 S8 silver with black half leather 2000 d2 S8 in Racing green pearl, RS4 manual gearbox, 2003 A4 avant TDi 1997 Volvo V40 2.0T 1992 Mazda eunos v spec 1976 Reliant Kitten 1965 Porsche 911 |
#64
i think this is it
#65
this is a audi manual page 4
#66
i think i understand it now there is a spur gear drive on the front & rear output out of the gearbox so although the rear diff is 4.111 the the actual diff ratio the gearbox produces is 3.726 for the rear and 3.730 front this complicates the gearbox choice further. so the gear charts need reproducing with 3.726 ratio.
#67
So any calculations for the 5HP24a have to take in to account the spur gears as well. Interesting.
Changing the spreadsheet to 3.73 makes 5th in the FBG identical to 6th in the DGV. That shouldn't affect manual gearbox choice though. A 4.111 rear diff with the 5HP24 is still valid for a 4.111 01E, since its the internals of the 5HP24 which monkey around with the figures (if I'm understanding the data correctly). Last edited by MikkiJayne; 26th March 2017 at 08:56 PM. |
#68
Hi there. I also have ambitions of converting my S8 D2 to a manual. Reading this thread has made me realise far more of an experimental task than I'd realised. Has anyone had any progress/success since March?
Cheers |
#69
#70
Oooo. I'll be keeping a close eye to see how you're getting on. Thanks
