Old 20th December 2017, 07:04 AM
Default D3 Xenon headlight performance
So
I used the D3 at night for the first time in ages yesterday, and it was quiet apparent the light output of the headlights is poor. I'll take a stab and say the 14 year old Xenon bulbs are beyond their best and maybe shifting colour temperature.
I thing they will be D2S bulbs, perhaps someone can confirm. I am also guessing its a major ballache to change them?
I have no workshop faclilities and only a muddy driveway to work on, anyone fancy changing the bulbs if I get replacements.
The headlights are not clouded over, as I had them sorted last year to get through the MOT as they had fogged up badly.
Old 20th December 2017, 08:28 AM
Mine are too, new bulbs didn't help so much. I polished the coating off the outsides due to aging but the inside optics are milky. It's not really the time of year for sticking some microfibre in the back on some wire as I have sene on youtube. Were yours cloudy inside or outside?
If you do change the bulbs, just do one first and then see what the difference is, otherwise you will never be able to decide if it is placebo effect. To change them you really have to remove the front wheel arch liner and this is easier when it's warmed up a bit rather than stiff and cold.
Once the liner is moved you can steer the wheel out of the way and access is very easy if, not the airbox and power steering reservoir may need temporarily moving.. Doing from under the wheelarch is much easier even if it sounds difficult.
Old 20th December 2017, 09:11 AM
Johnmed's Avatar
Johnmed Johnmed is offline
I bought some replacement LED headlights for mine, and realised as awkward as it was I didn’t need to remove the wheel arch, bumper or headlight. I did partially remove the power steering reservoir mount on the near side, and would have likely removed the air box on the far side.
It was a horrid job and ultimately pointless as the LEDs I’d bought didn’t fit my xenon (D2S) headlight enclosure. I’ll attach a few pics, don’t know if it will help.
It made me less likely to replace the bulbs TBH, just cos of how much of a pain access is.
ID:	17639   Click image for larger version
ID:	17640   Click image for larger version
2007 Mini Cooper S R56
Old 20th December 2017, 10:06 AM
Mine were just changed for me by one of my mechanics. its a bit of a faff to do it - things like the air box have to come out on the offside one.
I bought these from Jawad Malik at Xenon Bulbs Ltd in Leeds - he supplies a lot of the car guys with bulbs and has his own Xenon bulbs made which keeps the price down. Pleased to say so far they are very good -
http://www.xenonbulbs.co.uk/Xenon-HI...S/OEM-D2S-PAIR
The only other thing you can do if that doesnt improve things is to either replace the Projectors themselves in the headlight units with new Morimoto ones (Trups does this at EM Tuning at a cost) or change the headlights for a new one
Old 20th December 2017, 06:18 PM
tonupkid tonupkid is online now
Worth bearing in mind that higher K bulbs will be all white and bright and all that, but just wait until your in rain or, heaven forbid, mist. You'll be driving blind.
IIRC the OEM is 4300k.
Old 20th December 2017, 08:05 PM
H-M3 H-M3 is offline
What does the ballast do then? Does that have any link with brightness?
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 20th December 2017, 08:25 PM
The ballast generates the high voltage that drives the bulb. Can be up to 20,000V to ignite and 85V to run.
Old 21st December 2017, 07:36 PM
I think the shift in colour temperature is whats going on with my bulbs, I swear that with the slightly damp road with oncoming traffic it was literally like driving with the lights switched off.
Old 21st December 2017, 09:28 PM
neeldub neeldub is offline
Originally Posted by mannyo View Post
So
I would have gladly helped if you were in London or the surrounding areas mate
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 22nd December 2017, 12:15 AM
Good forum spirit
