Old 8th April 2018, 07:50 PM
Extra plumbing for the auxiliary heater:
Plumbing - LPG evaporator down by the AC compressor.
Plumbing - tee for the coolant feed to the evaporator (which uses the heat from the engine to evaporate the liquid LPG in to gas)
Plumbing - an interesting valve doodad for the aux heater on the right hand side
Extra wiring for the LPG system
Lots more wiring for the LPG system
Wiring disconnected and ready to remove
Here's a bonus complication of the manual - the clutch slave cylinder hiding on top of the gearbox. Slightly challenging to remove, extremely challenging to refit!
The manual exhaust support bracket is quite tidy with both of them attached together under the gearbox.
Engine out:
ID:	18332   Click image for larger version
ID:	18333   Click image for larger version
ID:	18334   Click image for larger version
ID:	18335   Click image for larger version
ID:	18336   Click image for larger version
ID:	18337   Click image for larger version
ID:	18338   Click image for larger version
ID:	18340   Click image for larger version
ID:	18341   Click image for larger version
Old 8th April 2018, 08:06 PM
I didnt think you would have it all removed by tonight! What with all the complications of LPG/aux heater. If it was me I probably would only have got as far as removing the bumper by now!
Old 8th April 2018, 08:09 PM
The weight balance of the manual drivetrain is considerably different to the auto. The manual gearbox is 100Kg lighter so the centre of gravity is around cylinders 3 & 6 rather than at the bellhousing, so it needs a chain on the front of the engine to lift it flat.
Extra coolant pipe for the aux heater
Lots of plumbing here, for the aux heater and lpg
Engine harness and coolant hoses removed
Right in the middle of this pic is a lovely bracket to hold the clutch hose. Almost impossible to reach with the engine in
Both downpipes come off together which is really cool because it means they will both go back in exactly the orientation they came off. That makes reassembly much faster since I can bolt them up fully with the engine on the ground. With the auto you can't do this as its impossible to get them back in the same place so it has to go in with the bolts loose to allow final repositioning once it's back in the hole. Of course any time saved here will be consumed by trying to fit the clutch slave cylinder back in to the gearbox
Split CV boot, as is traditional. Black grease everywhere.
The manual wiring harness is much simpler than the auto harness
Vera very kindly brought some non-alcoholic workshop beer
ID:	18343   Click image for larger version
ID:	18344   Click image for larger version
ID:	18345   Click image for larger version
ID:	18346   Click image for larger version
ID:	18347   Click image for larger version
ID:	18348   Click image for larger version
ID:	18349   Click image for larger version
ID:	18350   Click image for larger version
ID:	18351   Click image for larger version
Old 8th April 2018, 08:15 PM
It's taken about 8 hours to get to this point. I can have the engine out of mine in 4, but I've obviously been taking extra time on this one due to those extra complications, and also explaining to Vera what I'm doing on the way
This particular 8 is a joy to work on - it likes being mended, unlike some which fight back at every turn!
Old 9th April 2018, 06:23 AM
It looks in remarkably good condition in terms of pipework etc - what's the mileage/km-age on the original engine? Presume it's done quite a lot of miles if someone's coughed up for LPG install....
The drive home to Germany should bed the new engine in nicely, so long as Vera can keep away from the loud pedal too much
Old 9th April 2018, 12:22 PM
Spanker's Avatar
Spanker Spanker is online now
I guess that by the end of the year, you'll have had ALL the calendar cars through the workshop. You've already had January, July, September and November that I know about
This thread brings back some nice memories.
Shame we won't see the car in person at the annual meet (unless you want to drag your heels MJ and then you can come in it ).
Dean
Old 9th April 2018, 04:19 PM
Haha nice try but Vera needs to go home in it on Sunday!
170K miles. Apart from the insatiable thirst for dino squeezings the engine is in amazing condition - hardly any leaks, nice clean oil and coolant, and Vera has had it to the rev limiter in 6th It just uses loads of oil at <3000rpm.
Old 9th April 2018, 06:24 PM
The oil should be clean. Its new every few 100 miles!
PS> waiting for this evenings installment
Old 9th April 2018, 07:05 PM
nice work as usual mj
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 9th April 2018, 08:17 PM
Not a great deal to report today. Mostly removing ancillaries from the engine, and removing the centre exhaust silencer which turned out to have a hole in it. Luckily the excellent folk at A8parts had a full system in stock and were able to cut it to the exact length needed to fit with Vera's Supersport back box so dodged a bullet there!
I also removed the LPG injectors from the old engine. You can see the LPG adapters just underneath the original petrol injectors:
Pretty neat little things actually, which save you from having to drill the inlet manifold. I don't like the way the fuel rail is suspended on nuts and bolts though so I will tidy that up
The old engine all nekkid
I had to adjust my engine and gearbox separatey thing to fit the manual gearbox
Once the engine and 'box were split I cleaned up the gearbox and removed all the clutch fork stuff as that's all being replaced with new along with the clutch and flywheel.
Lots of o-rings and things coming tomorrow so I can reattach all the original water pipes etc to the new engine and start putting it back together
ID:	18360   Click image for larger version
ID:	18361   Click image for larger version
ID:	18362   Click image for larger version
