Some of you know from another thread that for sometime now my D3 has had issues with the ABS controller ECU and a single wheel speed sensor failing to report once the car warms up, and generates an electrical fault in circuit error.
So today, I dove the car to an as yet unnamed establishment although at least one forum member knows where to get the ABS ECU removed and repaired. Fast forward a couple of hours and the car is started in the workshop having been put back together but its obvious something is wrong. They then spend at least two more hours taking things apart and rechecking. Things are now a lot worse than before, I've gone from having an intermittent (the car needs to warm up) ABS wheel speed sensor fault to a hard ABS error as soon as you start the car. I've now got this error http://wiki.ross-tech.com/wiki/index.php/01200 along with Invalid being reported against all the wheel speed sensors in VCDS The ABS, traction control light and a flashing red (!) in the speedo and one flashing in the top left of the widescreen DIS plus when I get to 20mph I get a parking brake error which remains on until I slow to a stop only to beep and return again at 20mph. I've not named the establishment yet as they are working with me to fix the issues. As they are 1.5 hours from me, I needed the car to get home otherwise they would have carried on working on it tomorrow. They are going to call me when they have some news to get the car back in, but they are currently saying the electronic module may need replacing but they did not know about the parking brake error. I'll attach a VCDS scan once I have redacted the VIN number. I have cleared all the faults from this scan, only the ABS fault and parking brake return. I drove the car home, leaving them at 5.30pm.
Here are two full scans
One is a scan once I got the car home, obviously tainted by the removal of the ABS ECU The second one is a scan after a code clear but before starting the engine, the 01200 error returns once started. I think they've borked the ECU, heck I've even tried disconnecting and reconnecting the battery since to see if that clears the fault. Tomorrow I am going to take the connector off the ABS module and check they have not bent any pins.
Stupid question, but the fuses have been checked ?
Supply voltage is a pretty distinct fault. It means, there isn't +12 where there should be. There aren't too many reasons for that. (bent pin at a push, but you're way more likely to kink a thin data pin than a thick power one ?) If the ABS module was toast, you'd likely not be able to talk to it. ABS, is also responsible for generating the main speed signal in the car which is used for virtually every other module - Air suspension raise/lower, Sat Nav speed pulse, Steering for servotronic, parking brake to know when to release, PDC to auto switch off, ACC for obvious reasons ! So, I think it could look way worse than it actually first appears.... I've had a faulty ABS module before, and the parking brake bleated every time I set off (very annoying) but its just being over cautious as it knows there's an ABS fault and it may not know (or trust) the current speed of the car. That fault went as soon as I had the ABS module 'reconditioned' (which basically involved breaking it open, and resoldering all the dry solder joints on the board that occur as a result of it being physically located right next to the coolant header tank for the last decade or so, is my understanding..... This is why it works when cold, but once the coolant warms up and expands the joints again, it fails I believe)
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
There is a 60amp fuse that feeds the ABS module, in addition to other, smaller feeds.... I suspect that juicy feed it want makes the ABS pump and valves dance when needed.
I would defo be checking all aspects of that 60 Amp feed, its quite probably that could be at fault, but the electronics of the module could be powered and happy.
IT, you were spot on with the fuse hunt.
They did check fuses, but I did not remember them going into the passenger side end of dashboard one. I know they did the drivers side as there is grease on the cover. In the passenger side fusebox is a 25 Amp fuse labeled as Electronic Stability Control, it had blown to pieces. Luckily I had a spare, so replaced it and fired up the car. Result no faults showing on dashboard, I then left the car idling to see if the fuse blew again and it did not so I took it for a drive. Normal service resumed, a clear dash with no fault lights even after going for a drive. They are familiar with most VAG group cars, and I think mine was the first A8 that issues with. I guess they did not know about the other fusebox, so did not check that side. I'll email them shortly and let them know my findings, and save them trying to source a replacement module.
A perfect example of why this forum is fantastic, and such a vital source of information and experience for us A8 owners
![]() I could sense your despair mannyo after the disappointing visit to the unnamed establishment, you'd been looking forward to them being able to resolve your ECU "issues", and it appeared they'd failed miserably. Share your findings on here, along comes IT armed with his extensive knowledge and experience...a short while (and no more expense) later all is good in the world again ![]() ![]()
Audi D3 S8 - 2007 - V10. B&O, Phantom Black, black and silver interior, and still completely standard with everything working as it should ![]() ![]() Audi TT - 2015 - Ultra |
Thanks
I was a little worried yesterday, until Ians post, and now quiet relieved to have a normal looking instrument cluster.
What a great result, so happy its up and running properly again
