Old 26th January 2019, 06:37 PM
Default No saving this one!
Its coffee table time
Those who know the fleet may remember the black FE which I bought from Paignton for its red interior. At the time, the owner said he could see a conrod through one of the spark plug holes so I knew the engine was toast when I bought it. Unfortunately, he was sold it by a shady car dealer in Oxfordshire as 'needs a new starter' He put a new starter on it but it still wouldn't turn over. Read on for why...
Pulled the cam covers and had a look at the tensioners. A bit of a tramline on top, but not terrible
Underneath, not so good!
This is all that was left of the tensioner pad in the head!
Pulled the inlet manifold next. I know these can contain little surprises, and as expected it had a bit of a rattle. Two inlet valves! They're not supposed to be in there
Cylinder 1. Oh dear. Thats one of the inlet valves.
Cylinder 2. Aaand thats the other one
Cylinder 3
Cylinder 4
Off with its head!
#1 has a hole in it
#2 has, um, gone
#2 rod is bent at the end, but amazingly still attached to the crank and still moves smoothly!
The head did not fare well The other head is also damaged due to bits of exploding piston going through the inlet manifold and in to the cylinders on bank 2
#2 con rod. Amazing it didn't break since the 40v rods are supposedly the wek point in the engine.
#1 piston has a hole in the middle
#2 piston is in small bits in the sump!
These are the two largest chunks, plus the remarkably unscathed gudgeon pin. You can see a 15mm piece of valve stem at the bottom of the pic - thats all I can find of them. No idea where the rest went.
Pin circlips and some bits of piston ring
Another tiny bit of the cam tensioner pad
There's almost nothing salvageable on this one - the cams, a few sensors, and the valves from bank 2. The inlet manifold flaps still move, but its full of metal shards so would need completely stripping and cleaning which isn't really worth it. I'm hoping at least one piston and rod is still usable which will go in to my Avus FE's original engine which is recoverable.
A friend is going to make a coffee table from the block and four of the pistons, and I'm going to make a desk lamp from the crank I'll post up pics once they're done.
ID:	20771   Click image for larger version
ID:	20772   Click image for larger version
ID:	20773   Click image for larger version
ID:	20774   Click image for larger version
ID:	20775   Click image for larger version
ID:	20776   Click image for larger version
ID:	20777   Click image for larger version
ID:	20778   Click image for larger version
ID:	20779   Click image for larger version
ID:	20781   Click image for larger version
ID:	20782   Click image for larger version
ID:	20783   Click image for larger version
ID:	20784   Click image for larger version
ID:	20785   Click image for larger version
ID:	20786   Click image for larger version
ID:	20787   Click image for larger version
ID:	20788   Click image for larger version
ID:	20789   Click image for larger version
ID:	20791   Click image for larger version
Old 26th January 2019, 07:20 PM
Is that the one with the red interior that you picked up near me?
If so I didn't realise that engine was fixable.
Old 26th January 2019, 08:21 PM
One head is mashed, as is the piston where the valve dropped, but the bore is mostly ok. There's one tiny ding in it but the piston moves past it smoothly so its recoverable. All it needs is another head and the one piston. It won't ever be perfect, but I'll just put it in something disposable for a laugh
Old 26th January 2019, 09:51 PM
Simonbartlett Simonbartlett is offline
A new starter and an oil change and that would be good for another 100k 😁
Owner of a 2008 A8 3.0tdi SE
Old 27th January 2019, 11:35 AM
Wow. Properly Fubar'd
I'm sure you could fix it though MJ!
Interesting how it seems to be the middle inlet valve that's bent in each case. I suppose the interference is greater/closer for that valve?
Old 27th January 2019, 12:08 PM
Yeah that one has the least clearance.
Old 27th January 2019, 01:35 PM
The_Laird The_Laird is online now
Jeez, that should have come with an X certificate and a warning not to scroll down if you’re of a nervous disposition! What a mess!
Old 27th January 2019, 04:31 PM
Nothing a bottle of Wynns wouldn't clear up.
Old 1st March 2019, 06:15 PM
This is the best reminder I have ever seen to change your pads
Old 2nd March 2019, 11:19 AM
B@fink B@fink is offline
I’ve taxed worse......
