Old 11th March 2019, 04:28 PM
I fear dizzlebizzle may have left us, but I have just replaced the cogwheel in my MMI for a brass one due it it snapping in half.
Having seen this thread I thought I would test before too far into reinstallation, and it is exactly the same. So for anyone else doing this, it is a common issue.
The walnut cover clips on a curved metal cover and this has a rack of teeth along each edge that engage with a pinion bu.t it is not possible to change the position of this easily as I would have to jump a few teeth and they are tight meshing. I only replaced the motor cog, so not sure how it got out of sync.
Old 12th March 2019, 09:23 AM
Not sure if this is useful or not?
MMi Cog Replacement to Screen Mechanism
Old 12th March 2019, 05:42 PM
Thanks Architex_mA8tey - what great instructions, much better than the ones I used. I have sorted the issue out and all back together.
Old 13th March 2019, 07:26 PM
Glad it helped
I've added it to the stickies in the relevant section plus the tech dump so it's there for anyone else
