Old 14th August 2019, 06:53 AM
carmel120 carmel120 is offline
Default battery coding
Hi just wondering if anybody has come across this I have changed the battery on the d3 and it wont accepted the new battery code threw vcds I have tried everything just keeps saying code rejected would the bem module be bad.
thanks trev
Old 14th August 2019, 07:25 AM
go back to the old code and just add +1 to the number so for example 12345678 would become 12345679, should work ok then
Old 14th August 2019, 04:48 PM
thanks for the reply I have already done that also but no joy.
Old 14th August 2019, 05:04 PM
What codes are you using?
What battery make did you choose off the popup list such as VARTA?
Old 15th August 2019, 06:37 AM
Hi sure ive tried a lot of codes but no joy and ive also tried every battery make on the popup list but no joy.
I can get the codes tonight when I get home.
cheers trev
Old 15th August 2019, 08:33 AM
Worth reviewing the Rosstech video guide for battery coding - can be slightly odd behaviour with number of characters and getting zero and O mixed up that can stuff it up
https://youtu.be/IJAScg6JrYI
Old 17th August 2019, 09:41 AM
JanKaj JanKaj is offline
Default Codes
Had no BEM on my new battery. Found this and used the code for 110ah -equal to the new one.
51Ah - 8K0915105J / 000915105BB / 000915105DC
60 Ah - 4F0915105 / 8K0915105G / 000915105DD
61Ah - 8K0915105H / 000915105AD / 000915105DE
70Ah - 4F0915105A / 8K0915105C / 000915105DF
72Ah - 8K0915105B / 000915105AF / 000915105DG
80Ah - 4F0915105B / 8K0915105D / 000915105AG / 4FD915105 / 8KD915105 / 000915105DH
95Ah - 4F0915105C / 8K0915105E / 000915105AH / 000915105DK
110Ah - 4F0915105D / 8K0915105F / 000915105AK / 8KD915105A / 000915105DL
68Ah - (AGM) 7L0915105 / 000915105CC
75Ah - (AGM) 3D0915105H / 000915105CD
92Ah - (AGM) 4F0915105E / 000915105CE
105Ah - (AGM) 4L0915105 / 000915105CF
115Ah - (high cap.) 4H0915105 / 000915105DM
Select]
[61 - Battery Regulation]
[Coding - 07]
[Battery Coding Assistant]
Enter the new Battery Part Number (10 or 11 digits).
Enter the new Battery Serial Number (10 digits). - X Y MM DD SSSS where X and SSSS -any numbers and y-year, mm-month, dd, date of production
Select the new Battery Vendor.
[OK]
[Do it!]
[Close Controller, Go Back - 06]
Old 18th August 2019, 06:34 PM
Smile
[quote=JanKaj;152271]Had no BEM on my new battery. Found this and used the code for 110ah -equal to the new one.
Select]
[Coding - 07]
Enter the new Battery Serial Number (10 digits). - any numbers will do eg. 9876543210
[OK]
[Do it!]
[Close Controller, Go Back - 06][/QUOTE
cheers mate I will give it a go.
Old 18th August 2019, 07:46 PM
Tiburon3 Tiburon3 is offline
Sorry... but no. This number tells the car how old is the battery.
I've made a huge investigation about this issue, and it's absolutely crucial in this kind of cars to make a good battery coding.
Please read this link from Audi Sport Ibérica (It's in spanish, sorry, but google translator will help you).
https://www.audisport-iberica.com/fo...r%C3%ADas-vag/
Audi S8 D3 Facelift 2008. Phantom black pearl effect, Ceramic Brakes, 20 x 9J ‘7-arm twin-spoke’ design polished rims, ACC, Auxiliary heater, Side assist, Rear & side electrical blinds, Audi Parking System Advanced, Power boot, Soft close, Kessy, Auto dimming mirrors, Solar sunroof with photovoltaic cells, Bluetooth and Mobile phone with handset, Side & rear laminated glass, Leather & trim package 3, Bose 6000, Audi Music Interface, Digital TV & Radio, TPMS, Rear Climatronic, Front confort seats heated, ventilated & massage, Heated & electrically adjustable rear seats, Through-load facility, Tyre Mobility System & 19" spare wheel, Fridge, Alcantara package, Homelink, External lighting package.
Wish list: B&O sound system, Rear ventilation + massage, RSE, MMI remote
