View Poll Results: Is the tube is supposed to be in the Engine bay somewhere? | |||
Yes | 1 | 50.00% | |
No | 1 | 50.00% | |
Voters: 2. You may not vote on this poll |
Should this mystery tube be under the bonnet? **UPDATE - MYSTERY SOLVED**
While I was cleaning up the plastic covers when investigating an oil leak yesterday, I came upon a mystery tube. It looks like the straw on an aerosol can. Should it be there? I pulled on it gently and it moves upwards several centimeters but I did not want to pull too hard just in case. It looks a little random to be where it is. Has it come off something engine related or is it an OOOP? Close view: Wide view: Thanks, Paul
1998 D2 S8 Jaspis Green Last edited by C4R 100N; 29th December 2019 at 01:02 AM. Reason: added picture of plastic covers |
I'm going with 'no' because that's not an OEM part I recall ever seeing before. What's it connected to? It looks like its just stuck in beween the wiring harness and the end of the inlet manifold. There's nothing interesting in that exact location iirc.
I could not see where the tube went; into the nether regions behind the back of the engine? So I positioned myself on the other (left hand) side of the engine, and gave another tug and shone a light from my phone towards the approximate place where the tube should be visible if it went to that side of the engine. I discovered that the tube is attached to a rubber breather? hose which is attached to the side of the engine. I've got no idea and I can't see the part in ETKA. I drew a red arrow pointing towards the other end of the tube where it connects to the rubber elbow which, in turn, seems to be plugged into the side of the engine (don't know what to call that bit where it plugs in). There is a wider view attached to this post. Any ideas?
1998 D2 S8 Jaspis Green |
oh wait, is that the vacuum supply to the fuel pressure regulator? The regulator is the cylinder in your second pic of the first post. It should have a vacuum line connected to the opposite end to the fuel pipe.
I'm sure I replaced my FPR a while ago and don't remember anything like that.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
This is a standard Bosch regulator as used in the D2:
The o-rings go in the housing in the fuel rail and the manifold vacuum connects to the port on the top. |
Looks extremely familiar and I'm pretty sure mine had an anonymous black vacuum hose.
(Though having just done a search, it was actually over 5 years ago so my memory may be faulty...)
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 28th December 2019 at 04:14 PM. |
That will explain the strong fuel smell that I have been getting - mostly on cold starts. Is it normal for fuel to dribble out of there? I remember replacing the FPR on my A6 sedan and it was leaking out of that top tube pretty badly. I think that I can go hook that up as I believe that I have some of that tubing laying around, what with owning 3 C4’s. **EDIT - UPDATE - MYSTERY SOLVED** It turns out that the rubber elbow was still installed on the FPR so I just needed to insert the wayward tube into the elbow and all is as it should be. I did not notice (obviously) that nothing was connected to the other end of the elbow on the FPR. On my C4's this connection was by way of rubber braided hose and was only a very short trip to the manifold. I have never seen the the hard plastic tube on my other cars. Perhaps it lasts longer or something?
1998 D2 S8 Jaspis Green Last edited by C4R 100N; 29th December 2019 at 01:05 AM. |
I get easily mixed up about how it goes wrong without it connected - I think it runs lean, but I'd have to look it up to be sure. The ecu can compensate to an extent with the O2 sensors. |
I've put about 2,500km on the clock since I've owned the vehicle - mostly joy riding - and it certainly has been a joy! Some of the most enjoyable km's that I have ever driven in a vehicle! I am loving this S8!!
