Old 25th January 2020, 09:36 PM
Are you sure you have a recent VCDS-Lite? It should go into measuring blocks exactly the same as the full version.
As for the cruise control, that could be the stalk, I know for a fact mine is dodgy and I've seen many comments over the years from others having the same opinion.
Cruise happens to be in the same area so I looked at that as well today and I could see that operating + or - functions on my stalk would occasionally just return a status of "off". That is consistent with what I find when driving in that it will sometimes just disengage randomly and quite often when I try to change the set speed. I think it's the slider switch that is the main culprit as the "set" button on the end seems relatively reliable.
Old 26th January 2020, 05:42 PM
hunker7 hunker7 is offline
This is the one I have : https://www.ross-tech.com/vcds-lite/download/index.php
Adjusted the switch, wasn't pressed properly with pedal released. Pushed in "one click" and now de-activates properly when brake is released.
Test drive tomorrow, fingers crossed.
Old 26th January 2020, 06:31 PM
Interesting, I've heard of switches that basically "auto-adjust" on a ratchet when installed, though you do really have to follow the sequence correctly. Pretty sure mine is just screw in on a thread and tighten a locking nut!
Maybe yours has been replaced with a newer version and whoever did it hadn't followed the process correctly?
Old 27th January 2020, 08:53 AM
Good news. Drive to work this morning, no lights on the dash and cruise control worked flawlessly.
Old 27th January 2020, 09:58 AM
Hurrah!
Old 27th January 2020, 10:17 AM
Excellent.
I just found this comment about measuring blocks in the online VCDS-Lite manual (https://www.ross-tech.com/vcds-lite/...sblocks.html):
Shareware Limitation(s): • You can only view groups 001-025. Groups 000 and 026-255 are blocked
So maybe you can't actually look at the brake switch measurements in group 66 using a third-party cable?
(I used to have VCDS-Lite but it was a fully-registered version that I paid for, so had fewer limitations.)
Old 27th January 2020, 07:39 PM
I should probably spend $99 on the "home mechanic" version as let's be honest here, I'm not driving anything else but Audis
Old 28th January 2020, 08:49 AM
C4R 100N's Avatar
C4R 100N C4R 100N is offline
Anybody tried VWtool? It should work with D2's at least.
vwtool.zip
1998 D2 S8 Jaspis Green
