https://www.ebay.co.uk/itm/Meyle-Lin...IAAOSw~FZf-sli
Will this fit my D2 that has steel uprights rather than aluminium? From reading the forum I've read that the alloy ones have different lower arm tapers or something? |
Both lower arms have different tapers on the balljoints. Meyle don't make a full kit for the 20" cars so you have to order all the arms separately unfortunately. They do specify a lower rear for the 20" but have no listing for the lower front - instead use one for a PF D2.
Thanks Mikki. So it makes even more sense now to go with alloy uprights but they seem to be quite impossible to find in UK..
1 off MEYLE 116 050 8293/HD TRACK CONTROL ARM Front RH,Rear,Upper 1 off MEYLE 116 050 8292/HD TRACK CONTROL ARM Front LH,Rear,Upper 1 off MEYLE 116 050 0140/HD TRACK CONTROL ARM Front RH,Lower,Rear 1 off MEYLE 116 050 0139/HD TRACK CONTROL ARM Front LH,Lower,Rear 2 off MEYLE 116 050 8228/HD TRACK CONTROL ARM Front,Front LH,Front RH,Lower 2 off MEYLE 116 050 8239/HD TRACK CONTROL ARM Front,Front LH,Front RH,Upper 2 off MEYLE 116 060 0006 ROD/STRUT STABILISER FRONT LH,FRONT RH
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
Thanks! this will save me a lot of time
