Old 7th December 2010, 01:25 PM
daz.g
Guest
Posts: n/a
Default Help - car has died.... ECU ??
Hi all,
Travelling along this morning and the oil level light popped on. So I stopped,topped up the oil but the light remained on. Definitely enough oil as read on the dipstick so thinking a faulty sensor I continued on my journey. About 20 miles later in traffic, just shunting at low speed and the car suddenly died. When attempting to restart it I had all the gears ( D,R,1,2,3,4 etc ) all lit up red. Engine management light and abs light also permanently on, it turns over but won't fire up. Just had fault codes read and the gearbox is saying missing command from ECU, Engine says missing command from ECU and any attempts to connect to the ECU directly fail ?? I've been told by a local garage that an ECU fault is plausible.
Does a faulty component on the ECU seem likely ?? After my alarm horn exploits I'm quite keen to try to repair it myself as I've heard there can be problems with drains blocking and water getting in there, does this all seem plausible to you knowledgable bods ??
Worst case scenario I understand I'm looking at the best part of 1K to get a new one and I've seen some A8 ECU's on A8parts - Does anyone know if these are different units or are they just generic ECU's flashed with a different program ??
any help/advice from you chaps is much appeciated as I'm feeling really deflated now and IF there is a good time for car problems it certainly isn't 2 bloody weeks before xmas
Help ....
Old 7th December 2010, 01:37 PM
If You cannot connect to ECU then it sounds like ECU or wiring/power problem. Which car is it? I have spare ECU for PF S8 AHC engine. I can also adapt immobilizer to accept new ECU if You are local.
Old 7th December 2010, 02:16 PM
daz.g
Guest
Posts: n/a
Its a 2000 facelift S8... can't remember the engine code off hand.
I'm guessing the drain plugs have been blocked earlier in the cars life resulting in water getting at the ECU. Its annoying cos I'm really on the ball at keeping them clear since I've had it.
Whilst waiting for recovery it did start on one occasion,ran for about 5 seconds then died again. With my electronic mind that just shouts dry solder joint to me, some kind of intermittent contact. My garage are going to get it out and try rebooting/reprogramming it but if that fails I'll have a look myself and see if there's any obvious pcb damage/dry joints/blown components etc
Cheers for the offer tho mate - You wouldn't happen to know if the ECU is different between models then would you ?, Would there be a difference between the FL A8 4.2 ECU and the FL S8 4.2 ECU ??
Old 7th December 2010, 03:33 PM
Yes, there are lots of different models of ECU out there. There will be a part number on it if you give me that I can find any alternatives for you.
Old 7th December 2010, 04:22 PM
daz.g
Guest
Posts: n/a
I've left the car with a garage so can't get to it to read the code - will it not be the same for any other 2000 FL S8 ?
Old 7th December 2010, 04:43 PM
I have found 5 ECUs for the AQH and 9 for the AVP engine you might have in a 2000 FL S8.
Old 7th December 2010, 04:54 PM
daz.g
Guest
Posts: n/a
ahhhhhh !!
Its an AQH so that narrows it down a bit I suppose - I'll find out the code when the garage gets it out ( and asks me to bend over )
Old 7th December 2010, 10:59 PM
If you change the engine ECU, you need to recode the immobiliser on a 2000 car as it is bult into the keys, instrument cluster and Engine ECU....
As far as I'm aware, this is an Audi only job. They're unlikely to be happy to fit you a 2nd hand ECU and code it, but in my experience if you fit it, then tow it to Audi and claim your car 'wont start' they should code it up.. ...ah hem...
unless you're real pally with the service manager in which case he might be more receptive to what you need..
I was pretty sure the oil level sender went direct to the instrument cluster though, not via the engine ecu, so it flagging up an error, wouldnt really tally with an engine ECU fault...
Wonder if the gearbox ecu has gone.... its odd that its lit up all the lights like that.... Much easier to change over the gearbox ecu, just plug and play... no coding to worry about...
Old 8th December 2010, 05:04 AM
daz.g
Guest
Posts: n/a
cheers for the info IT.
If the gearbox ecu had died would I still have a problem connecting to the main ecu ?? As I can connect to gearbox and engine and they both chuck faults about missing command from main ecu??
As to it being an audi only job to recode the immobiliser would noone else be ablto do this. From online research there are companies that will repair/rebuild/reflash the ecu's and my local 'audi approved' garage made no mention to this being an issue......
Also I've been thinking, would the differing part numbers for the ecu's just account for a different program installed?, so the physical circuit board itself is identical and the presence of a certain program denotes the part number??
Old 8th December 2010, 05:42 AM
Ben at Shark Performance can do a lot with immobilisers and things only Audi 'should' be able to do, sorry to hear about your problems. I'm sitting in a hotel in New York, havent seen my 8 in two weeks but it will be waiting for me at Heathrow this weekend for a nice blast home, looking forward to it!
