Old 27th May 2021, 09:24 PM
Gearbox next. As usual, I will flip it over to get to the sump and filter, however normally when I do that the diffs are drained ready for re-sealing. This one though is not leaking and so I'm not touching the output flanges and not draining the diffs. That means that if I flip it over, the gear oil will all leak out of these breather holes:
So, I printed some polyurethane plugs for them which worked very nicely
The ATF is nice and clean
I flipped it over to remove the sump. This bolt was stuck and stripped out. I cut a slot in it with the grinder and then persuaded it loose with a cold chise. There are usually a couple stuck on this side because the holes here go right through and the end of the threads get rusty. I have plenty of spare bolts so not a problem.
Stuck bolt at the top with crusty threads. All the other bolts were nice and clean.
Nice and clean in the sump - no fluff on the magnets. The phone had considerable trouble focusing on the shiny surface.
Evidence of a leak on this corner
Left it overnight to drain. New filter and sump back on tomorrow
ID:	26491   Click image for larger version
ID:	26492   Click image for larger version
ID:	26493   Click image for larger version
ID:	26494   Click image for larger version
ID:	26495   Click image for larger version
ID:	26496   Click image for larger version
ID:	26497   Click image for larger version
Old 28th May 2021, 07:42 AM
Markiii Markiii is offline
looking good, hows the F125 test?
Old 28th May 2021, 08:02 AM
Not opened it up yet - thats another job for today
Old 28th May 2021, 05:39 PM
BTW meant to ask, what condition are the rads in?
Old 28th May 2021, 06:07 PM
Not inspected them up close, but I didn't see any problems when I took the front panel off.
Old 28th May 2021, 08:02 PM
Finished off the gearbox and completely forgot to take any photos New filter and gasket, cleaned the sump, primed the pump - the usual drill.
At Mark's request I dismantled and inspected the F125 while it was easy to get to - nothing unusual to report and everything ship-shape so I re-greased it and bolted it back together.
Contacts are all good
Gearbox reassembled and back on the separating table for, er, 'un-separating' tomorrow
Once the engine and box are bolted back together I can spin the engine on the starter to get oil pressure, and then put the wiring harness back on.
ID:	26500   Click image for larger version
ID:	26501   Click image for larger version
Old 28th May 2021, 09:20 PM
RICKY D's Avatar
RICKY D RICKY D is offline
What state were the original tensioner pads like on this MJ?
On one of the pics they look new so I’m assuming you replaced them as part of the process.
Old 28th May 2021, 09:49 PM
They were actually pretty good - minimal tramlining, but someone had definitely been in there before so they may have been changed previously. I put new ones in anyway since it was all apart.
Old 31st May 2021, 07:59 PM
Another slightly frustrating weekend of back pain and breakdowns, but I made some good progress today.
I have built a magic box to simplify the process of spinning the engine to get oil pressure while its on the separating table. It plugs in to the oil pressure switch, has a couple of flying leads to connect to a battery, and the starter cables attach to the right hand side. The red button is a switch which lights up when it has power
Press the switch to activate the starter, and the green light comes on when there is oil pressure
5 litres of fresh oil in to the gearbox (6 in total - 1 litre went in to the pump when it was upside down)
Took the engine and box off the separating table and put them back on the subframe to refit everything else. Spark plugs and coil packs on.
I'm swapping the engine harness (because of the missing connectors) and so I need to swap over the ECU, but first it needs breaking out of its jail
Cut slots in the shear bolts so they can be removed with a screwdriver
Escaped!
The replacement harness
Fitted to the engine
New coolant hoses
New O2 sensors as well
The engine and box are finally complete, at long last. As I'm replacing the control arms, I'll attach the lower arms and driveshafts to this tomorrow which will make it much easier to put back together.
ID:	26513   Click image for larger version
ID:	26514   Click image for larger version
ID:	26515   Click image for larger version
ID:	26516   Click image for larger version
ID:	26517   Click image for larger version
ID:	26518   Click image for larger version
ID:	26519   Click image for larger version
ID:	26520   Click image for larger version
ID:	26521   Click image for larger version
ID:	26523   Click image for larger version
Old 31st May 2021, 08:49 PM
Deckard's Avatar
Deckard Deckard is offline
That engine looks MASSIVE & really impressive seeing you get in there! 👍👍
Current ride
[b]'06 MX-5
Past rides
'07 Boxster
'08 Mini Cooper S
'17 BMW i3
'04 BMW 535d
'97 Porsche 993 C2S
'72 Porsche 911 2.4S
'90ish Fiat X19
