Old 27th July 2021, 11:22 AM
Magnets on the fuel lines
Is this actually 'a thing' - Never heard of it......
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 27th July 2021, 12:01 PM
It really is. It yields magical fuel consumption and power improvements by lining up all the fuel molecules as they go in to the engine
Old 27th July 2021, 01:07 PM
Right up there in snake oil terms with my all-time favourite - the 'kettle' that injects magic steam into the inlet and somehow disposes of NOx and PM10. You had to buy the special water from the supplier too, as regular water was just not good enough My favourite bit about it was the kettle was in the boot, so by the time the magic steam reached the inlet manifold via some plastic tubing it had turned back into water
Old 27th July 2021, 01:54 PM
Ronin Ronin is offline
So what are the plans for your fleet of 9 cars? are most of them just parts cars to feed customer car re storations?
surely keeping 9 D2's going is impossible time wise and probably financially too
Old 27th July 2021, 05:17 PM
Dolphin Grey S8 'Lilith' - the best one, never selling her
Big Red - daily driver
Barnfind FE - going to a new home when its finished
PF S8 - going to a new home asap
Murple - going back together eventually & may be a daily
T42 - 2.8 FWD, getting a 1.9TDI conversion for 1000 miles range
Avus not-FE with black & red - going back to Davey Blueyes eventually
39V Avus FE - gave it's life to save the barn find, shell getting weighed in
V7 Black FE - going back together eventually
Old 27th July 2021, 07:45 PM
Lots of rusty bits have gone off for powdercoating, including the springs which amazingly aren't broken! These have been blasted and will be recoated which will hopefully prevent cracks forming in the first place. They're then baked to make sure there is no moisture left in them before the zinc-rich powder primer is applied.
The powder oven is at 200C by the way - well below the annealing temperature of spring steel so it won't have any effect on the springiness of them
Old 28th July 2021, 09:53 AM
So which mythic Lilith is it named after?
Old 28th July 2021, 11:07 AM
Whichever one you fancy She was so-named after I discovered she needed a new engine shortly after getting her home. Little did I know that she was one of the better examples, on the scale of what I've seen in the last few years, and so actually doesn't really deserve such a title. It stuck after I did the black and red interior though
Old 28th July 2021, 01:03 PM
Probably the Seductress then.
Old 31st July 2021, 09:34 AM
The power steering leak has ruined the rear right subframe bushes. At £50 each, I'd rather not replace eight of them, so I cut up a bad subframe to rescue the bushes from that instead.
The donor subframe was toast anyway
Rescued used bushes in nice condition
This one has been dissolved by the power steering oil
The dirty bits are where the rubber was split
Someone has damaged the access holes for the rear arm mount
Some heat from the mapp torch and a little percussive maintenance and they're back in shape
This is one of the reasons for the catastrophic oil leaks - the last time the timing belt was done the special o-rings on all the cam end-caps weren't replaced but just smeared with silicone. There are two sizes of these, and alas this small one is NLA so I'll be experimenting with traditional round-section o-rings to seal these up again. Luckily the larger ones are still available from Tradition.
Cam locking tools kindly on loan from Prestige
The oil leaks have contributed to the oil cooler pipe being completely destroyed
Its as bad down on the block as Big Red was
Cleans up ok though.
ID:	26825   Click image for larger version
ID:	26826   Click image for larger version
ID:	26827   Click image for larger version
ID:	26828   Click image for larger version
ID:	26829   Click image for larger version
ID:	26830   Click image for larger version
ID:	26831   Click image for larger version
ID:	26832   Click image for larger version
ID:	26833   Click image for larger version
ID:	26835   Click image for larger version
