Old 3rd December 2021, 12:55 PM
I’ve had the ‘tight fit’ problem with knock-off centre caps, but it’s easily fixed. Just snip a bit of the circular spring off (a teeny bit at a time)n with a pair of pliers until the fit is more comfortable. Simples
Old 3rd December 2021, 01:47 PM
As noted earlier in this thread.
the spring ring is usually a major part of the problem and needs about 5mm cutting out of it so it will close further, or a weaker replacement.
