Old 17th January 2022, 11:00 AM
I think this is the little fella we are looking for. Let me know if it the right bit, PM me your address and I'll get it in the post.
Cheers Frank
ID:	27703   Click image for larger version
Audi S8 D2 2002 88k mls
Old 17th January 2022, 12:29 PM
Bear in mind they are both different sizes, for the front and rear arms
Old 18th January 2022, 11:02 AM
I'm a little confused now so just to clarify before I send the wrong bit.
This insert is for the ball joint end of the "banana" shaped rearmost, lower front control arm.
Is that the correct one?
Cheers Frank
Old 18th January 2022, 05:10 PM
Mossyboy1978 Mossyboy1978 is offline
Correct! If you're looking at the hub from under the centre of the car it's the one on the left at the bottom. The banana shaped arm ball joint goes in it
Thanks
Mossy
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust.
Old 18th January 2022, 06:51 PM
Thanks for the clarification.
I'll pop it in the post tomorrow.
Cheers Frank
Old 19th January 2022, 12:18 PM
On its way bud.
Old 19th January 2022, 02:34 PM
Thank you very much!
Tags
carrier, nearside, wheel hub
