Old 9th June 2022, 08:07 PM
CaifanSC CaifanSC is offline
Default Glue for exterior door moldings? (Pix inside)
Hello fellow 8ers,
Does anyone know what kind of glue was used to secure together both pieces of the door moldings?
For some reason, when I purchased Cappuccino (my '01) it had the black rubber moldings removed for both front doors as well as the small pieces in the front fenders (wings). I'm finally getting around to installing them, but the driver side door (LHD) molding is split into two. Based on the residue in both halves, it looks like they were held together by some sort of adhesive. Any clue what kind of adhesive i should be using? I'm sure it's not your run-of-the-mill glue.
Help is appreciated!
Audi V8 Quattro Original 5speed - Black/Black
Audi S8 - Avus/Oxblood
Audi S8 - Cashmere/Twist
BMW 850i - Red 6speed
BMW 850Csi - Red 6speed
Ford Thunderbird x 3 Supercharged & 5speeds
Mustang convertible
Range Rover Autobiography - BRG/English Tan
Old 9th June 2022, 08:17 PM
They aren't supposed to be glued together so I suspect that's someone's attempt to repair them. The outer plastic part should just clip in to the aluminium inner.
To glue them together if they won't hold themselves together I'd recommend a 2-part methacrylate adhesive designed for plastics with low surface activity - these often come with a primer / activator solution which is usually MEK, a fairly vicious solvent. From memory, the strips are polypropylene which is a pain to stick with normal adhesives.
Old 15th June 2022, 10:08 PM
I think I see the clip you are referring to. It's in the middle of the trim piece (I circled it in red in one of the attached pix). Mine seems to have that clip broken. There's definitely some sort of adhesive, so you are right. Someone probably tried to repair it at some point.
I may just try some strong cement-style adhesive and see if it holds. Otherwise, it looks like I'll have to source another piece.
ID:	28669   Click image for larger version
Mustang convertible
