Old 13th September 2020, 07:32 AM
Default Headlight level sensor 4B0 907 503A
Hi all,
I have stumbled across the OE manufacturer of the D2 headlight level sensor 4B0907503A: Febi Bilstein. This is the first OE part I've seen from Febi tbh and on that basis they warrant an upgrade in my personal supplier ranking from Tier 2 high quality aftermarket to Tier 1 OEM This sensor is used on everything of the D2's era - A4, A6 & TT so still in production.
Check this picture where the Febi part has had the OE markings sandblasted off. Same font and location for both 'made in Germany' and the date stamp.
In this pic you can see the same parting lines from the injection mould:
Febi part number is 37932
Retail on this from TPS is £104 but the Febi version can be had for £50 if you search around
ID:	23903   Click image for larger version
ID:	23904   Click image for larger version
Old 13th September 2020, 05:11 PM
That's a good discovery. Well done MJ
Old 14th September 2020, 09:50 AM
pete-p's Avatar
pete-p pete-p is offline
That's good research. I sometimes get the warning if stuck in traffic for a while.
Cars...
Old 30th December 2020, 10:16 PM
Ronin Ronin is offline
£45 on amazon now!
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
just bought 2.
Old 4th December 2021, 08:14 PM
radyah radyah is offline
Does this work for both front and back?
Thanks
Old 4th December 2021, 09:17 PM
Yes, same part front and back.
Old 7th December 2021, 05:49 PM
thank you for the info
Old 19th June 2023, 10:56 AM
I’ve just got my S8 back from having the front subframe repaired and the headlight level light popped up immediately.
On a scan it says “1 fault found, 00776 - level control system sensor, left front, (G78) 31-00 open or short to ground.
Can I assume that this is the sensor inside the left wheel arch and not the control unit? It doesn’t;’t appear that the arm is broken, so I suppose the electrics have gone for some reason?
Old 19th June 2023, 11:28 AM
Assuming the sensor was disturbed while removing the subframe, it may just be a legacy fault if the ignition was turned on with the sensor disconnected. Have you tried clearing the code to see if it comes back?
If it does come back it could be a bad connection. I'd have a check and make sure the connector is fully seated, maybe remove it and give it a squirt of WD40.
If that doesn't help then replace replace the sensor.
Old 19th June 2023, 11:57 AM
Thanks Michaela
