It was worth it, i highly reccomend
![]() ![]() ![]() ![]() ![]() ![]() I also replaced the heating valve block/motor If someone plans on doing this, it took me about 9h start to finish with no breaks. Result = I now have a car with working heat and AC ![]() |
Did you follow the manual? Any tips / handy hints along the way?
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
One tip I can give is to start flushing with a very low pressure and wait for water to start coming out the other end, once it starts coming out then you can safely increase it.
Also you will find quite a few corroded connectors in the ECU box so have contact cleaner ready. |
Also this diagram is useful:
![]() I flushed each heater core in 2 directions as well. |
