Old 3rd March 2011, 09:08 PM
Default Coolant/temp warning signal
Weird one this.
Came on this morning whilst turning left onto a slip road with a 944 on my rear. I was rather enthusiastic in the hope of seeing a sideways and panicing tailgating prat. Only a little run wide sadly. Went out once on the straight after a few seconds. Didn't come on again despite spirited driving including a fast, sharp, right. Engine temp steady at it's usual spot for a cool day.
Came on twice on the way home, on both occaisions going round a sharp left.
I take this to mean that despite the coolant level being above the min. mark, the coolant is in need of topping up.
Am I correct to discount a failing fan? It was three degrees this morning and similar this evening so no reason for it to be on and as it only happened going round left hand bends it would suggest a swilling of coolant exposing a pipe and allowing the water pump to cavitate possibly and freaking the ecu.
Any flaws in my reasoning? (please don't let it be a failing pump )
Bill
Old 4th March 2011, 07:23 AM
Topped up, it shut up.
Old 4th March 2011, 02:11 PM
Have you also bled the system?
Old 7th March 2011, 07:57 PM
No gurgling in hoses and I'm an arse so no. Sorry dad. I'll do it school tomorrow.
Old 4th May 2011, 09:05 AM
Water leak traced to pump. N reciept for water pump change at cambelt service which suggests this is the standard failure at 100k or so. Bah. cost me my brake upgrade and put the car off the road on the 17th of April when I was meant to be sopmewhere far more entertaining.
