Old 19th February 2011, 04:41 PM
You should be able to get an in-line lance attachment that is for use in applying foam (or cleaner solution etc) it basically looks like a plastic bottle with an in and an out screw thread feed and some come with a section of lance already on them too
It kinda looks like this
Old 20th February 2011, 09:29 AM
Zip's Avatar
Zip Zip is offline
Sorry - I wasn't clear. I'm using one the one that came with my washer. Just wondering if the posh brass ones are THAT much better....?
Zip
Old 20th February 2011, 11:30 AM
I wouldnt say so Zip, not for home use - the brass ones tend to just be heavy duty versions that are built for much more use really - Im not sure of the cost difference but I dont see any difference/benefit in their use over the standard ones. . .
Old 29th March 2011, 01:33 PM
Night Train's Avatar
I'm using one of the brass jobbies and Valet Pro Ph Neutral foam now...
Other vehicles
Oh Yes....... The '98 PF S8!
Old 29th March 2011, 02:03 PM
Zip's Avatar
Zip Zip is offline
...and how much better is your brass jobby?!
Zip
Old 29th March 2011, 04:02 PM
Its certainly better than the one that came with my pressure washer (Karcher 650M) which was plastic, but also has a detergent reservoir built in (but never mastered that)
It holds a lot more of the snow foam mix (holds a litre), so I can be really generous with 2 cars at a time.
Much more adjustable, in spray pattern & mixture to high pressure water ratio.
But whether you'd consider that £50 better, I don't know.....
its obviously of much better quality manufacture, and far more durable than its predecessor.
I'm not disapointed in my purchase...
bought it from monza car care...
Other vehicles
Old 29th March 2011, 06:17 PM
Where's the best place to get a snow-foam lance for my karcher then?.. None of the usual places I look have them
Old 29th March 2011, 08:04 PM
darrenjoe90's Avatar
richard i just looked on ebay and there is loads of them. just type in snow foam
Audi S8 Phantom Black
Old 29th March 2011, 08:22 PM
I got mine from http://www.monzacarcare.com
Other vehicles
Old 30th March 2011, 08:15 AM
D'oh!.. eBay...
