Old 22nd May 2011, 09:15 PM
Yup... All FE's will have one as they had the GSM hands free phone prep as standard....
Old 22nd May 2011, 09:32 PM
Originally Posted by James7 View Post
What am I looking out for if its got sports mode? Is it the button on the right handside of the gear knob? Probably an easy question but I'm still on a steep learning curve with regards to my S8 knowledge
James
if its got S mode it will be the last position in the gate ie the one furthest back from the engine, below the D position, the button on the right of the knob is what you push in when changing the position of the selector, ohh and S is good, very good!!
HTH
cheers
Old 23rd May 2011, 08:24 AM
S-mode is good fun, but not as much as tip
Old 23rd May 2011, 08:30 AM
What S mode looks like on gear selector:
On earlier models you have 4-3-2-(1?) gear selectors which is about as useful as a chocolate teapot when you have tiptronic control on the steering wheel
Old 23rd May 2011, 12:52 PM
James7 James7 is offline
Guys
Thanks for the S8 school lesson on the triptronic box!!
James
Old 23rd May 2011, 03:15 PM
The 4-3-2 can actually be handy as it stops the box going above that gear, but really only any use if you're towing and need engine braking going downhill
Old 23rd May 2011, 05:13 PM
or in snow if you want to control the wheels from spinning! ie use a higher gear
Old 23rd May 2011, 05:20 PM
Thats true for most cars, as you can force the gearbox into 2nd for a steady set off, but doesnt work on the A8, it'll start in first no matter what, so the gearshift is a 'max' setting rather than an absolute one...
Makes it all the more pointless !!
Old 23rd May 2011, 05:58 PM
Guys
Is sports mode an optional extra or was it standard on the S8 and from what year onwards??
Thanks
James
Old 23rd May 2011, 06:15 PM
It was standard from 2001 if I remember rightly, but it really depends...
I wouldn't worry about it, you're better with tiptronic anyway.
