Old 23rd May 2011, 10:32 AM
Snaga Snaga is offline
Thanks for the input guys. If the service book is correct the ATF was changed at just over 40k by Audi, so shouldnt need doing again.
Old 5th June 2011, 06:31 PM
A8 Doc A8 Doc is offline
Will need it doing again mate. That's the honking noise.
And to be honest go to an independant and they will do it properly. Audi suck the oil out with a special tool. Always better dropping the pan, changing the filter and letting it drain overnight..
Old 6th June 2011, 12:56 PM
So should i be worrying if i dont get it done straight away?
Old 7th June 2011, 06:59 AM
How much should this gearbox oil change cost me?
Old 7th June 2011, 02:13 PM
£200 ish
Old 7th June 2011, 05:14 PM
thanks. So £355 is well above the odds then?
Old 7th June 2011, 06:22 PM
355 isn't horrendous.. I'd expect about 300 or so for the full job with fluid, filters, etc.
Old 7th June 2011, 07:05 PM
11-12l of oil @ around £8 per liter, £30 for the filter an rest for the job.
Old 19th September 2011, 07:17 AM
Audi charged me £200 I remember. Basically cost of the oil!
They won't change the filter though, go to an independant if I were you.
Old 26th September 2011, 10:11 AM
jamestoo jamestoo is offline
Smile My Honking now sorted!
Hello
This is my first post and what a great site!
Today I've just had an independent garage change my 4.0l 2005 A8's (its just done 80K Miles) transmission fluid after reading about it on here.
The "honking" got progressively worse and can now report its completely fixed no honking and silky smooth.
Just wanted to say thanks for a great resource
James
