Old 21st June 2011, 02:18 PM
Default RNS-D in PF
Found this on e-bay: http://cgi.ebay.co.uk/1999-Audi-A8-S...#ht_2442wt_905,
wonder how difficult would it be to fit in PF car??
Old 21st June 2011, 02:22 PM
I had it running on a PF car, so its do-able, but its a right PITA.
heated seat wiring changes slightly, fog lights change completely and require an external latching box as PF ones latch, and FL are momentary - Hazard warning light changes, but most of the Audio wiring is simple changeover. Heated rear window moves to climate module too, but thats a fairly simple wire move
Biggest problem as ever is the A/C module, which whilst its fundamentally the same wiring, the FL module uses a can signal to know if the engine is running to switch on the A/C compressor - No Can on PF, so no A/C without some other clever stuff. On My S8 I had a can signal generator to put the speed signals on the bus for the climate, but seriously, its a lot of messing about for little gain....
Old 21st June 2011, 02:25 PM
That's what I thought
Old 21st June 2011, 02:26 PM
Is it just as hard to put the original RNS C unit that came with some PF models in? You can't get the PF double din from Audi anymore though sadly.
Old 21st June 2011, 02:30 PM
No, thats pretty easy as all the switch gear is PF - Quite a quick job really.
Might as well buy an RNS-D, fit the square RNS-C facia to it (a few screws) and enjoy a much better Sat Nav for the same effort pretty much.
Old 21st June 2011, 02:36 PM
Thats the plan, I know Paul Waterloo has an RNS C fascia for sale at the moment too. I wonder if it would be possible to make an RNS E small enough to fit into a PF double din original sat nav thing?
Old 21st June 2011, 02:45 PM
Dont see why not, but I think it would look a bit out of place imo.
The PF is a classic piece of Audi kit now, I think the RNS-E would look well out of place. At least the PF was available with an RNS-C, and the RNS-D looks indentical, so that would pass in my purist eyes...
Old 21st June 2011, 02:58 PM
I hear what your saying but its got to be better then some Kenwood/Pioneer setup. I'll see if I can get hold of a double Audi setup. Please let me know if you come across any.
Old 21st June 2011, 03:40 PM
for a single DIN setup my 1st thought would be for a fold out screen for when you want nav - I know it's not OE or even close to it, but on the hassle to fit front it sounds a much simpler option and probably less likely to be noticed by thieving so-and-so's.....
At least you'd have DVD nav and most likely bluetooth added at the same time.
Old 21st June 2011, 04:26 PM
I suppose its viable for some, I'd never go non OEM on a headunit. Heck I didn't even let Autoglass fit a non OEM windscreen.
