Old 1st November 2011, 09:14 AM
i only used to get full pull from the engine at above 5000rpm and when it changed gear it dropped to 4000rpm A8 gearing remember so the pull from after the gear change was non existant before but now it pulls strong on the gear change
Old 6th November 2011, 06:43 AM
nope lol that truly was down to the intake manifold, after its all been done with new PTFE bushes its amazing really is like driving a different car im kicking myself for not doing it months ago
Did you take any photos of this fix? Where is the offending part are how doyou know if it's broken? I thought my car was a little hesistant on the track a week ago,
Old 6th November 2011, 09:52 AM
The problem is documented HERE Jim and there are addition threads about it on our forum HERE and HERE
Old 6th November 2011, 02:32 PM
Thanks!
Old 12th November 2011, 03:44 PM
i made my replacments out of PTFE worked great im still waiting to hear back off a company that are going to hopefully put them into production as a replacment part made of PTFE for me to make up repair kits and i will be selling them on the forum, this is moving a bit slower that what i intended but with it being a small fish the company have bigger things to do but it will be there for the offering at some point soon
Old 27th December 2011, 04:37 PM
plankton plankton is offline
I've done the test (flooring whilst in tiptronic mode) and it didn't change down, so my kickdown appears to be off. I've tried fumbling around in the dark with the thing below the accelerator, but I can't move it. It presses down, but doesn't move clockwise or anti-clockwise. Is there a knack to doing this, or does it just require more force??
Old 28th December 2011, 04:51 PM
I've tried again and this time it moved - it just needed a bit more pressure. Not tested properly (had a quick go, though it didn't feel a lot different than before).
Old 28th December 2011, 06:24 PM
You need to stomp the throttle so hard as to engage the switch in tip mode
Old 23rd March 2012, 05:18 AM
Jake242's Avatar
Jake242 Jake242 is offline
Is it just on facelift models or can it be a problem on my introduktion 94' model?
/Jake
Old 23rd March 2012, 06:52 AM
Just facelift. PF has switch on throttlebody
Tags
facelift a8 d2 kickdown
