Old 3rd January 2012, 07:34 AM
KPS's Avatar
KPS KPS is offline
Default Temp guage
Hi Guys,
Was driving yesterday and whilst sitting in traffic i noticed the temp gauge just going above 90. Only went up by a very little bit and soon as I started driving it went back to normal. Any thoughts on what this could be - im assuming thermostat. But i know that means a belts off job. Cambelt was changed at 80 something thousand miles and now is currently on 110,000. It was done by a main dealer so dont know if they changed thermostat and tensioners, etc, etc. Is it safe to drive until i next get the belt changed or do I need to get it sorted asap. Also vague price for cam belt change including thermo and water pump etc etc?
Thanks guys
___________
Kunwar
2002 Audi S8
Old 3rd January 2012, 07:39 AM
They ought to change everything else while they're in there but it's not part of the cambelt change job. Mine didn't get a water pump, but did have a stat
If it starts fluctuating regularly then get it changed early, but if it's getting up to temp and not then over heating it ought to be Ok to leave for now
Prices fluctuate wildly - camspec in Crawley are good - depends which side of London you are? If the belt you have is that new I'd be tempted to retain the tensioners etc and just have belt, water pump and stat done and reduce the next change interval accordingly
Old 3rd January 2012, 03:14 PM
Zip's Avatar
Zip Zip is offline
Question
Hyjacking slightly....but conversely, my temp guage is not rising much about 60 degrees at the moment after being stuck firm at 90deg for the last 4 years. More noticeable now that outside temp is dropping, and the inside of the car is a little slower to heat up.
I assume this is suggesting the thermostat is close to jiggered? Can I leave until next service?
Zip
2002 S8
Old 3rd January 2012, 04:14 PM
If it helps i have been running cold for 12 months. I'm not suggesting you leave it that long but as far as i'm aware it hasn't damaged anything and to be honest it dosen't seem to have made much difference to fuel.
http://forum.a8parts.co.uk/showthrea...t=running+cold
Old 25th February 2012, 01:46 PM
Went to change the thermostat today but theres no way i can get the bolts out, i have already twisted one torx bit and started rounding off the inside of the head with another. The only way i can see to get these out now is with a cold chisel or i take the front end off to get an impact driver in there.
Old 25th February 2012, 02:11 PM
I've got a set of screw extractors which dig their way into the damaged head and help remove a damaged screw/bolt - have you got anything like this Dezzy?
http://www.screwfix.com/p/screw-extractor-set/18643
Old 25th February 2012, 05:00 PM
You could try a bit of heat. not to much but heat and cool, heat and cool and you may get lucky.
Old 28th February 2012, 07:48 AM
I don't have any extractors mate but i will be investing in some, i was looking at the spiral type too for rounded hex bolts but don't know if they'll grip a cheese head
I'll try a bit of heat first as i'm trying to do it with the front of the car on, I can't get a drill in there with out. I stopped as i needed te car this week. I was also thinking about running the engine to get it up to temp and then that freeze stuff on the steel bolt
I just don't want to snap the head off, as i don't fancy tring to drill steel out of ali.
Could i have the part numbers for the 2 off bolts for the thermo housing please as they'll be no good if / when i get them out.
Old 1st March 2012, 06:17 AM
Bump for the part no for these bolts please
Old 1st March 2012, 06:42 AM
N 905 375 02
Hexagon socket oval head bolt (combi) M6X20 2 off @ £0.47 each
Name:	ABZ Thermostat Bolt.JPG
