Old 14th January 2012, 08:40 PM
Default check this out for winter traction
take a look at this then
http://www.youtube.com/watch?feature...&v=mkleAMR3IyI
never seen them before but look like great fun
Old 14th January 2012, 09:45 PM
Dezzy will have a one of these I am sure, only bigger
Old 15th January 2012, 02:18 AM
I have seen Land Rover on ebay with similar tracks a while ago. There was a choice given to buy just a car, just tracks or both and tracks were more expensive then car. If I remember correctly car was about 8k and tracks over 10k
Old 19th January 2012, 10:53 AM
I can't see the youtube at work but if it's a tracked Landrover then it's a "special project" that is called a Cuthbertson coversion and looked like this
and a LWB
How you got in them i don't know. Not 100% sure when these were first available but a Series 1 so 1950 something.
There is a company called Mattracks who make modern type tracks that fit your truck or car would be interesting to see a tracked 8, anyone?
There were various "Special" Landrovers built over the years some with rail wheels and a really interesting hover rover and a mobile cinema
ID:	2707   Click image for larger version
ID:	2708   Click image for larger version
ID:	2710   Click image for larger version
Old 19th January 2012, 11:05 AM
Whats the legalities of removing the wheels and replaceing with tracks
How do you measure for the legally require 1.6mm of tread across the centre 3/4 of the tyre for example....
Not that I'd want to, but was just curious as presumably you need some sort of exemption to run with non standard wheels on a vehicle ?
Old 20th January 2012, 02:54 PM
I don't know Ian; you defiantly have to have track pads to use tracked stuff on the road not sure how much rubber is left when they are worn. I suppose you may also need an H licence too?
Now i've seen the vid i see they are Mattracks
