Old 18th February 2012, 02:07 PM
mannyo mannyo is offline
Default VCDS Scan result
I had my 8 scanned today, below are the results.
Saturday,18,February,2012,14:37:40:10074
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
VIN: WAUZZZ4DZxxxxxxx
Address 01: Engine Labels: None
Part No: 4D0 907 558 N
Component: 3.7l V8/5V G 0001
Coding: 11753
Shop #: WSC 02313
VCID: 387B2CD332C3
WAUZZZ4DZ1xxxxxxx AUZ7Z0Y1xxxxxx
4 Faults Found:
16814 - Catalyst System; Bank 2: Efficiency Below Threshold
P0430 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
17977 - Cruise Control Switch (E45): Implausible Signal
P1569 - 35-10 - - - Intermittent
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D46
Coding: 08397
Shop #: WSC 23132
VCID: 316D11F7D1B9
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
31-10 - Open or Short to Ground - Intermittent
Address 08: Auto HVAC Labels:
VCID: 55A585678591
Note: Excessive Comm Errors
Address 15: Airbags Labels: 4D0-959-655-AI8.lbl
Part No: 4D0 959 655 T
Component: Airbag Front+Kopf 4000
Coding: 01417
Shop #: WSC 02335
VCID: 43814B3F7B05
No fault code found.
Address 17: Instruments Labels:
Part No: 4D0 919 035 AJ
Component: D2-KOMBIINSTR. VDO D29
Coding: 00483
Shop #: WSC 02313
VCID: 6ED7CA8B0007
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D17
Coding: 13130
Shop #: WSC 00000
VCID: 428F4E3B641F
7 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
00958 - Key 4
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 B
Component: Navigation BNO 0001
VCID: 326F1EFBD4BF
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 45: Inter. Monitor Labels: None
Part No: 4D0 951 177 B
Component: Innenraumueberw. D06
Coding: 00001
Shop #: WSC 00000
VCID: 285BFC93E263
Address 55: Xenon Range Labels: 4B0-907-357-DYN.lbl
Part No: 4B0 907 357 C
Component: dynamische LWR D05
Coding: 00001
Shop #: WSC 00000
VCID: 285BFC93E263
Address 56: Radio Labels: None
Part No: 4D0 035 195
Component: Radio D00
Coding: 00116
Shop #: WSC 02313
VCID: DFC9274F77AD
1 Fault Found:
00850 - Control Output Active; Radio Amplifier
29-10 - Short to Ground - Intermittent
Address 76: Park Assist Labels: 4D0-919-283.lbl
Part No: 4D0 919 283
Component: Parkingsystem A8 RDW D07
Coding: 01108
Shop #: WSC 00000
VCID: E8DB3C93A2E3
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4D0 927 156 DD
Component: AG5 01V 3.7l5V RdW 3838
Coding: 00001
Shop #: WSC 02313
VCID: 6ED7CA8B0007
End ---------------------------------------------------------------------
All fault codes have been cleared and have not returned, only one which I think may cause concern are the lambda / cat related ones, should I be worried about these as they do say intermittent.
Manny
Past
Old 23rd February 2012, 01:24 PM
Titan Titan is offline
I'm sure this is the same as the one I get every now and then;
It brings on the engine management light. I've had it in at the garage and it's apparently a sensor after the cat to measure how efficient it is.
The garage said they see this on cars without genuine Audi replacement cats. The car just passed an MOT and the emissions were all fine.
I reset the error code and it generally doesn't re-appear for a month or two.
Hope this helps.
Old 23rd February 2012, 03:40 PM
That handy to know, MOT is due soon here. I wonder if the codes are old, since I had no engine management light on before the codes were cleared. The engine management light is working fine as it comes on when you first turn on the ignition.
Cruise control, seems to have a mind of its own and from what I have read is a common problem. I dont really use it anyway, so its not something I'll miss.
Manny
Past
Old 23rd February 2012, 04:28 PM
Don't quote me, but this is how I think it's going. Your showing the initial symptons of lambda faliure on Banks 1 and 2 on the pre cat side. Only intermitant at the moment but may be indicative of an issue with the cats.
If that the case, then it is possible that the lambda after the cat is using the pre cat reading to check that the cat is doing its job.
Therefore you may not have issues with the cats or the post cat lambas, just the pre cat lambas on bank 2.
Bank one is an indication of Cats not doing its job properly and may be the cat.
Start with the pre cat Lambas being checked, then check post cat Lambas then if they show no faults get an emmisions test done.
As you have cleared the faults, and they were intermitent, give it a good blast on quality fuel (V Power) and see if they return.
Cheap petrol does not help these high strung beasties.
HTH
