Old 25th February 2012, 09:31 PM
Default whos going to be the first to put a LS3 in a 8?
Just been reading up about engines for fun, I have to say I prefer the simpler design of the American pushrod. Plust they sound great
I would love to put a LS3 with a Tremec 6 speed in my S8. Or at least I would love to see someone else do it.
A LS3 is much cheaper than I thought, £4350 from the UK. I guess the real expense would be all the other work to get it into the car.
http://www.roadcraftuk.co.uk/index.p...product_id=585
LS3 weighs 200kg, same as 40V V8? Tremec 6 weighs only around 58kg, thats about 100kg less than a Audi auto trans!
http://www.ttcautomotive.com/english/products/T-56.asp
However, LS3 also has a chain tensioner problem, it brakes. Some people have gone back to LS1 chain damper.
http://www.camaro5.com/forums/showpo...&postcount=223
http://www.camaro5.com/forums/showthread.php?t=153162
wohooo!
http://www.youtube.com/watch?v=M7-VpUgsZrM
Old 26th February 2012, 01:09 AM
sarg sarg is offline
anyone else have no idea what an LS3 is, or is it just me?
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 26th February 2012, 06:03 AM
No, you are not alone
Old 26th February 2012, 07:01 AM
its Basically the GM V8 engine fitted to Cameros, the C5 Corvette and most Holdens from 2008 onwards
http://www.camaro5.com/forums/wiki.p...specifications
Old 26th February 2012, 02:15 PM
sorry, I was a bit vague. yes its a pushrod V8, used in the Chevy Corvette and Camaro as Architex_mA8tey said
Old 26th February 2012, 05:33 PM
71camaro 71camaro is offline
And it's quite a good powerplant, and very common here in the USA. I'd personally drop the coin on an LS7 or LS9 though, they have 505 hp and 630 hp output, respectively, and are unbelievably reliable as well, and they take very well to modification. The LS9 is factory supercharged, and a simple pulley change and tune can get you into the 750 bhp range.
Old 28th February 2012, 10:10 AM
I was looking at the LS7 as well, amazing engine. Its a bit more pricey and I couldnt find a readily available source in the UK. I know some guys on here were looking at supercharging the Audi V8, I think they are better of with a LS3 or LS7, LS9 V8, could turn out cheaper and more powerful. Also they have cast iron cylinder sleeves, I'm no engineer but iron sounds better than Alusil coating.
Old 28th February 2012, 10:34 AM
Here is a better picture of the offending part in LS3 (and LS7 I beleive). Same as Audi, and pretty much every other manufacturer, they used some sort of nylon, which sometimes brakes at engine temperature.
Its a real shame because there are better materials out there such as Stanyl Diablo (recently selected by Fiat) and Duratron CU60.
And here is the thread advising replacement with the LS1 chain dampner. Shame because the LS3 tensioner looks like a better design because its keeping tension on the chain not just preventing vibration and jumping.
http://ls1tech.com/forums/generation...work-pics.html
If I ever have the money to get a LS3 this is the first part I would change before the engine went in the car.
Name:	LS3 chain tensioner.jpg
