Old 29th February 2012, 03:14 PM
Could do with rar extension for attachments so that anything that does not fit under other extensions can be compresses to rar and attached.
Zip is already supported, and is probably a more compatible method as most users are Windows based, and its built into the OS.... (well, since XP anyway)
Old 29th February 2012, 03:44 PM
I still got IP address in address bar.
Yes, so have I.
And if I use THIS shortcut "http://81.142.45.148/search.php?do=getnew" I get a list of new posts as expected.
BUT if I use "http://forum.a8parts.co.uk/search.php?do=getnew" I get a search page http://81.142.45.148/search.php
and then clicking on New Posts gets the required result...
Is this a result of DNS not yet updating and the "old" forum linking you to the new one?
tracert takes me to 86.54.174.194 which is presumably the old one?
Maybe not! 81.142..... is at BT, 86.54..... is at kcom. I'm confused.
Old 29th February 2012, 04:08 PM
In short, its still DNS. Yes.
In long, DNS Propagation is 8 to 48 hours depending on how aggresively the downstream DNS servers cache the entry, so I wouldnt expect it to work until tomorrow morning for anyone really.
Old address is KCOM (86), new address is BT (81)
The problem is that the old Kcom server has an HTTP redirect on it, so whilst IP addresses still resolve forum.a8parts.co.uk to that server, it forwards them on to the correct IP.
The odd thing is that it forwards on, with the full path, but only up to the first ? - Hence
becomes:
Which is what you're seeing.
When DNS propagates, then you will land directly on the correct BT IP address and the full URL will be parsed to the PHP script taking you to exactly where you need to be.
I'm sure I could fix the redirect off the Kcom box, but frankly, I've got a lot on, and for the sake a few hours, it'll resolve itself just fine
Old 29th February 2012, 04:14 PM
Yes yes, K com is exactly what I though. You could try cross referencing the Doss network on the type 21K profiling on a AMHTP setup, have you tried that?
Sorry, I haven't a clue what you guys are on about.
It was quick in the past and is still quick now, carry on and thanks for keeping it running and putting the hours in Ian.
Old 29th February 2012, 04:22 PM
Thx Amar, kind words always appreciated....
Old 29th February 2012, 04:40 PM
Public DNS records are now working correctly for me.... That was much faster than I expected. Cool.
Old 29th February 2012, 04:42 PM
That explains my confusion!
And as I'd understood you'd moved from BT I was bemused by the kcom server..
DNS I've found can actually propagate quite quickly, but it's not a problem.
Old 29th February 2012, 05:02 PM
Now updated here too.
Old 29th February 2012, 05:27 PM
sloss's Avatar
sloss sloss is offline
It's even propagated all the way to Aberdoom...... a lot faster here too although my BroadBean is very slow anyway
Old 29th February 2012, 05:52 PM
Zip's Avatar
Zip Zip is offline
Thumbs up
Gee Thanks! You're too kind. Nice to know I'm supported.
Zip
