Old 20th April 2012, 09:33 PM
Nollywood's Avatar
I'm not scared to sort out a valve problem, as that can be done with the block in situ,
You've lost me, Ian. The cylinder head will still need to be pulled to replace a burnt-out valve.
Old 21st April 2012, 12:03 PM
Yeahhh Ian!
I haven't got a clue really
Old 21st April 2012, 12:42 PM
But that does not require engine to be pulled out.
Old 21st April 2012, 12:47 PM
Yes, thats where I was going with this....
Probably my terminology being a newbie at oily stuff
If its a valve problem, I only need remove the offending head, which can leave the rest of the engine in place...
If its pistons, then that seems like more major surgery.....
Old 21st April 2012, 01:26 PM
Pistons... Ooh...
If I was paying, it'd be as cheap with an engine swap probably, but seeing as you'll be getting mucky. Should be able to do it with the engine still in the bay, but it'll be a fiddle.
Old 21st April 2012, 06:34 PM
The plot thickens.
Removed some more stuff out of the way for access, bought a new compression tester, and tested all cylinders, and both banks.
I have 2 cylinders off, both opposite each other on seperate banks, both reading a value of around 4 bar, compared to the 9/10 bar on the healthy cylinders.
Defo an engine swap / breaker now, but what are the odds of having two cylinders broken..... ???
Old 23rd April 2012, 06:30 PM
adjuster adjuster is offline
I don't have much experience with the LPG fueled engines, but I've seen where an injector sticks open, and will flood the cyc. with fuel.
This washes the rings, and drops compression, and of course, the super rich mix does not burn, so you get a misfire.
Wet plug and low compression were what I found. Added some oil, it brought compression up, but as soon as the engine was run, it misfired again.
Pulled the injector, swapped it with another, and the "bad" cyc moved...
Sonic cleaned all the injectors, and it "cured" the problem for that vehicle. If not, I was ready to replace the bad/stuck injector. (But upon pulling them, they were all filthy, so new fuel filter, sonic cleaned the injectors, keeping the bad one seperate so it did not get confused with the other 5 on this I6 engine.)
The coil and plug was fine, the valves and pistons were fine. Rings were fine, but washed with too much fuel, they don't seal up well at all.
I would imagine if you ran the engine at a high enough speed/RPM, that the right air fuel ratio would be reached, and the misfire would go away. (Depends on how stuck open the injector is.)
Old 23rd April 2012, 07:40 PM
Hmmm - Thanks for that. Thats very interesting.
I do now have 2 cylinders off, and I just cannot get my head around the miniscule probability that I have two failed cylinders.
More interesting is that whilst they both read only 4 bar of pressure, only one of them has a wet plug. The other is dry.
I wonder thus if I might have one failed valve/piston, and one injector problem....
Time for some more spanner work me thinks...
Old 24th April 2012, 11:25 AM
Zip's Avatar
Zip Zip is offline
Question
Sorry for off-topic question......
what's a "Hertz" audio upgrade when it's at home?
Zip
Old 24th April 2012, 02:28 PM
If it's the one I'm thinking of, then it's aftermarket stereo gear... along the lines of Bose, etc.
