Old 18th May 2012, 06:06 PM
47p2's Avatar
47p2 47p2 is offline
Is the 3000 not enough to remove any blemishes? Reason I ask is the more different grades you use the more you run the risk of going through the lacquer and causing damage.
Also where do you get the 3000 grade from?
Nite Blue 3.0L SE Quattro
Old 18th May 2012, 07:47 PM
Night Train's Avatar
I only used them very gently as 3000 grit takes forever (obviously wet with copious washing up liquid in the water!)
obtained from a seller called ..... motorwayshop on a certain auction site... HTH
Other vehicles
Oh Yes....... The '98 PF S8!
Old 18th May 2012, 08:25 PM
47p2's Avatar
