Old 5th August 2012, 01:13 PM
elvis elvis is offline
Default tronic problems
has anyone the idea about the tronic problems ?
my tronic in my audi a8 d2 dosent respond to the manual tronic comands,
and the displat in the instrument panel dosent apear
D 1 2 3 4 5
Old 5th August 2012, 01:55 PM
cerips cerips is offline
Have you had the fault codes read?
Old 5th August 2012, 02:03 PM
Sounds like the tiptronic gear box isn't getting the message that you want to change from auto to manual from the gear selector so I would look at that first.
If the shifter picked up the change to manual when you move it to the side then the display would be changing to show manual gears.
Old 5th August 2012, 10:30 PM
nothing happend when i move the shifter to the tronic position
the problem must be in transmission electronic module or in shift contacts?can u explain to me?
as i told up the screen of transmission dosent apear in panel
Old 5th August 2012, 10:32 PM
cerips no i have not
where can i find or read this codes ?
Old 6th August 2012, 03:53 AM
What year and engine size is your A8?
There are 4 parts it could be I guess -
The gear lever selector itself
The Harness for the selector lever (Item 1)
The gearbox ECU itself (item 1 on the pic below)
or possibly the F125 switch (item 7 on the pic below)
The F125 switch is something known to fail more often, but you would be best advised to plug in a diagnostic cable and this may well point you in the direction of the faulty item
ID:	4153   Click image for larger version
Name:	Gear selector mechanism.JPG
ID:	4154   Click image for larger version
ID:	4155   Click image for larger version
Name:	F125 Gearbox Position Switch.JPG
ID:	4156   Click image for larger version
Name:	Harness for Selector Lever.png
Old 6th August 2012, 08:00 PM
my AUDI is V8 4200 cc year 1995
Old 8th August 2012, 12:07 AM
architex can u give me aspecific answer
Old 8th August 2012, 06:55 PM
Get a garage with a diagnostic machine to read the error codes to diagnose what the problem is.
Old 8th August 2012, 08:36 PM
I was as specific as I can be in my answer above, unless there are any differences with a Pre Facelift model then its still scan first to see if any codes come up then look for one of the 4 issues in mentioned/listed
