Old 16th August 2012, 03:23 PM
Good luck in your task. I'll make it a sticky when you suceed.
A8Parts may be able to help and could have some useful parts.
CtL
Old 16th August 2012, 04:56 PM
The D3 unit is a motor located at the right hand side of the boot that works the hinge for the lid. Gets a signal from the central locking to open, and from a button inside to close.
Old 16th August 2012, 10:26 PM
71camaro 71camaro is offline
How different is the hinge? If I could get the OE D3 mechanism to work, that would be optimal. Electrically I can make it work fine, I'm just worried about hard attaching points, how different they are.
Old 16th August 2012, 11:47 PM
heres the D3 layout - item 37 is the motor and 3 and 5 are the hinges
and heres the D2 bootlid -
ID:	4540   Click image for larger version
Old 17th August 2012, 12:34 AM
Pics aren't working for me, unfortunately. If someone would post that has had both a D2 and D3 I think that would be best.
Old 17th August 2012, 05:54 AM
Try again now, I've uploaded and embedded the images this time
Old 17th August 2012, 06:34 AM
That works now. I can't get vagcat to open on any of my devices or machines. I'm not too sure why. Is the site down? Or are my freedoms to browse being impeded (wouldn't surprise me, but I don't dare turn this thread political).
Also, they appear similar enough I may be able to make it work. I'm going to pick up hinges at least, found a pair for only $45 (roughly 29 pounds). I can go from there methinks. I already know the latching mechanism will work.
Old 17th August 2012, 07:31 AM
I thought the hinges looked pretty similar too, would love to get an OEM solution for this on mine.
I think VAGcat must be limited in functionality to people outside of Europe. Try using http://openproxy.co.uk/ and then access it through there.
Old 17th August 2012, 10:19 AM
This link is useful to understand the D3 system:
http://audiforum.us/threads/audi-a8-...ear-lid.12168/
You can download "Boot lid.pdf" file, which includes extract from ELSA about D3 boot lid drive.
Old 17th August 2012, 11:12 AM
47p2's Avatar
47p2 47p2 is offline
The hinge on the driver side has a pin which the motor slides into, this is what raises and lowers the boot when you operate the motor.
I have the old motor from my D3 which I replaced as it would not lift the boot without some assistance. It could be that it just requires new brushes to have full power again, or it may even work on the D2 boot lid depending on the weight of it. New motors sell for around £400-£450 so if you are looking for a bargain drop me a pm.
There is an attachment on this thread post #5 by PsYcHe which gives some detail
Nite Blue 3.0L SE Quattro
