Old 26th August 2012, 01:54 PM
elvis elvis is offline
do u have any other idea ainarssems excepr welding?
Old 26th August 2012, 02:08 PM
Well welding would be cheapest and simplest option and you can use the gearbox and ECU that you have. Possible issues is length of gearbox and possible balancing issue on diff after welding.
I suppose you could keep automatic part of gearbox, take off centre diff part and you might be able to find a FWD final drive that fits, possibly from 3.7 or 2.8 FWD car that fits. Or make custom drive from gearbox output to front diff. Unfortunately I cannot recommend any specific, I am afraid you need to do your own research. I length is not issue just weld it up maybe take centre diff to dynamic balancing after welding.
Old 26th August 2012, 02:14 PM
i have a 4.2 engine .if i take off the torsen the rpm from engine will go in front output and no in torsen ?how does function quattro ?from engine to torsen and next at the weels ?can anyoine explain this?
Old 26th August 2012, 02:18 PM
found anything about transmission?how can we use quattro trans for and fit for fwd transmission
Old 26th August 2012, 03:28 PM
On 4WD you have centre diff(torsen in most cases) at the end of gearbox and you have output from it to rear propshaft and a shaft going to front diff. On FWD you just have pair of gears that drive shaft going to front diff in place of centre diff. Iknow there are 4WD and RWD version of HP24 but do not know if there was ever FWD HP24 box, id there was you could use parts from it on your gearbox. On the other hand it could be possible to use parts from FWD HP19 box but I am not sure if they will fit.
Old 26th August 2012, 04:09 PM
Here I got a picture of boxes. On the left you have 4WD boxes and on the right FWD boxes. The automatic gearbox part should be the very similar(marked green in picture) but on 4WD boxes there is a transfer box bolted at the end of it marked in red and cover with pair of gears(yellow) on FWD cars. Like I said before I do not know if there was ever FWD version of HP24, If there was you could take transfer box off and get cover , gears and shaft and cover from FWD version, if not then you might be able to use parts from FWD HP19 but I cannot guarantee this without having both boxes and comparing parts. Or yo could make custom parts. But like #i said before if length of gearbox is not issue easiest and most cost effective solution would be to weld up center diff in transfer box.
Old 28th August 2012, 07:20 PM
ainarssems thankyou for the help u give to me
maybe syncro s8 another member of forrum can halp me about this
do u understand wht i am going to do?
i need use my 4wd automatic transmission but imust eleminate the rear output and let the ission with front output and then i put the engine and gerabox in the middle of the chassis.but i dont know how to realise this with my gearbox and not with other gearbox.maybe one possibility is to remove the torse or middle differential,this is wht i think.this s why im goinge to ask all u
Old 28th August 2012, 07:35 PM
no one has any idea plz find anything
it is very important for me
Old 28th August 2012, 09:10 PM
Elvis,
If you dont want to use a FWD transmission then you can weld up the center diff so that the output to front and rear is identical. Try googeling it. Link here.
Old 28th August 2012, 10:01 PM
Elvis,
This has been discussed before but in some cases there is issue with 4WD box length. On 5HP19 you can just take transfer box off the end and use shafts, gears and end cap from FWD 5HP19 but there was never FWD 5HP24 or 4HP24. It might be possible to use parts from 5 HP19 but I am not sure.
