Old 1st September 2012, 11:24 PM
tallon tallon is offline
yeah it varies you can get things pretty cheap on ebay if you just keep checking but the trans can come from a passat that's the one I have, audis, BMW's and Porsche have the same transmissions but probably a bit expensive from porsche.
I wasn't sure if I'd need the trans unit but I bought it anyway and the connector. Just bought the cheapest one, they range from very low to very high prices.
Used stuff is cheap man I bought this like new car for $1000
Old 2nd September 2012, 05:04 PM
elvis elvis is offline
no im trying to use my transmission .in the sketch wasnt not dificoult to do it .just take the gears of the torsen and it work with first output./
if i dont realise this i will work more make some money and bye a fwd transmission but i think i ll do it im optimist
thnxs ainarssems fot sketch help
if u have something more u send them to me i ll made my supercar fly
Old 2nd September 2012, 09:07 PM
cerips cerips is offline
Just sell your 4wd gearbox and get a fwd gearbox, you'll probably end up with some money left over as the 4wd box is worth more.
Old 2nd September 2012, 09:37 PM
no i like to try by my self
there is not any problem transforming it just take away the input shaft to the torsen
Old 5th September 2012, 05:24 PM
I didn't say there was a problem doing it I said it won't hold up to the v8's torque when used like that.
I'm afraid our cars won't be "flying" with these setups since you won't be able to be able to floor the gas pedal too much. When my transmission is destroyed I'll probably have a new plan altogether. Should have more money by then.
There are benefits to using the more expensive manual transmissions. They are the only ones strong enough.
Still wondering why you are embarrassed to say what car you are building.
Old 10th September 2012, 08:30 PM
hi mens
the transmission cost too much and i cant paty .im trying to use this in my car
Old 10th September 2012, 08:43 PM
Building cars isn't a cheap hobby
I look forward to your outcome, though and hope it works out.
Old 20th September 2012, 04:09 PM
Default ,,,
how is the weight of te audi a8 engine V8 4.2 petrol?
Old 20th September 2012, 05:23 PM
Around 200Kg if I remember rightly.
Old 29th September 2012, 09:30 PM
how is going anyone any new for transforming the 4wd in FWD?
