Old 4th September 2012, 07:56 PM
Default 3.7 OEM exhaust diameter
I am thinking of getting some chrome trim to brighten up the back of the 8, but unsure of what diameter I should be getting to put on the tailpipes. I just think it will look better with chrome rather than the twin black pipes popping out the back.
Old 4th September 2012, 08:04 PM
or you could see if A8 parts have an S8 Back box which would keep it OEM and do the same thing for you ?
Youll need to check if it will fit the 3.7
Old 5th September 2012, 10:48 AM
You can brighten up the ends with emery paper, wire wool as the system is stainless anyway
Old 5th September 2012, 01:46 PM
RanjS8 RanjS8 is offline
Default Standard back box exhaust tips
So are the standard back boxes stainless steel under the black paint.???
