Old 4th September 2012, 09:18 PM
wiingg wiingg is offline
Default Glovebox light not working
I noticed that the glove box light wasn't working last week, tried a lamp that i have to checked to be in working order and that didn't want to work either in the glove box either.
As i had some spare time on my hand i removed the glovebox and checked at the connecter (think it's about 6 pin) for a 12v supply to the glovebox switch. No 12v supply at all.
The fuse is in the drivers footwell and that is all in order. I wondered if anyone had any ideas on what the issue could be
I doubt the glovebox light will ever be needed but it almost kills me knowing its not working
Old 4th September 2012, 09:36 PM
Slight disgression I know but I have a problem with my glovebox light and don't know how to remove the glovebox to get at it - what's the method?
Old 4th September 2012, 09:48 PM
Amanda Amanda is offline
Screws .........the metal variety hidden inside and underneath
Old 4th September 2012, 09:51 PM
Thanks, so empty the glovebox and hunt for the usual well-disguised screw heads covered in furry stuff? How many roughly and are any difficult or easy to messup/lose?
ELSAWIN told me to do it as follows (pics are for a left hander but it all seemed the same), i literally dropped the glovebox as opposed to removing the lock cylinder etc as listed also below
Storage compartments/covers
Removing and installing glove compartment
1. Lock cylinder
o ◆ For glove compartment
o ◆ Removing and installing
=>Page 68-5
2. Opening mechanism
=>Page 68-5
3. Hexagon socket-head bolt
o ◆ 2 off
4. Bowden cable
o ◆ For glove compartment lock
o ◆ Disengaging from opening mechanism=>Page 68-5.
5. Nut
o ◆ Self-locking
o ◆ 2 off
6. Lock
7. Bracket
o ◆ For dash panel
o ◆ With speed nut
8. Glove compartment
9. Hexagon socket-head bolt - 2.5Nm
10. Hexagon socket-head bolt - 2.5Nm
Removing
• ‒ Open glove box.
• ‒ → Unscrew glove compartment frame -arrows-.
• ‒ Pull glove compartment frame backwards out of guides.
• ‒ Detach connectors and lay aside glove compartment in passenger's footwell.
• ‒ → Unscrew glove compartment lock from glove compartment -arrows-.
Installing
Installation is carried out in the reverse order; note the following:
• ‒ If glove compartment will not close or if there is play adjust glove compartment lock by moving it in slots -arrows-.
Old 4th September 2012, 09:56 PM
Ah right, so you took the whole thing out including the "roof" where the light is mounted?
Thanks for that, a job for another day methinks.
Old 4th September 2012, 10:00 PM
Yep, all pretty simple to take out. I was hoping i would find a loose connection and it would be a easy fix... but sadly not!
Old 4th September 2012, 10:35 PM
RanjS8 RanjS8 is offline
Default fuses
Do a continuity test across all your fuses in the fuse box....It might be a not so obvious fuse....Failling that I would check the wiring diagrams in elsawin and see if you can trace the wire back....not an easy task at all....
good luck
ps taking the glove box off is easy really...just three bolts as shown above...putting it back now I have to say it is the one job I absolutely hate on this car....lining up the holes, holding the glove box up and getting the bolts in....such an awkward job hate it every time!!!!!!!!!!!!!!
Old 4th September 2012, 10:44 PM
I take it that means pulling the fuses one by one and testing or is there a quicker method
Old 5th September 2012, 09:48 AM
sloss's Avatar
sloss sloss is offline
Using a Mulitmeter set to the beeper alarm just touch each visible end of the fuse while it's in position, it should beep: no beep = duff fuse/connection.
Don't hold it on for long as, depending on type of meter, you may complete the circuit and have current going through the meter.
As you are checking a small part within a circuit there will be no shorting or problem caused elsewhere
