Old 12th September 2012, 07:28 PM
wiingg wiingg is offline
Default Bi-Xenon sidelight removal
I had a quick look at removing the sidelights from the rear of the headlight but it kind of looked like that the bulb should be removed from the front.
So can someone enlighten me for sure
Old 12th September 2012, 07:52 PM
RanjS8 RanjS8 is offline
Default Sidelights
To change the sidelight bulb, you unclip the plastic black cover.
The holder that holds the sidelight bulb has clips on the side that keep in place...so just squeeze on these and pull the holder will come out with the bulb.
Old 12th September 2012, 09:16 PM
You need to change one of yours Ranj - one looked yellow and one looked white after the regional meet in Cobham the other day
Old 12th September 2012, 10:05 PM
Thanks for that, much appreciated
