Played with it some more this evening and finally managed to get it to recognise the 2005 navigation CD.
Basically when I put the disk in, the firmware upgrade screen was popping up all the time. Previously I selected the End option, and pressed return after popping the disk back in. This is what resulted in the system saying "navigation being activated". This time by chance rather than pressing return, I pressed the right hand knob inwards and it worked. Up popped a message "Loading navigation data" and a couple of mins later I was back in business. Tidied up the wiring behind the unit this evening, and removed the Video in motion button from the plug and play loom as it will never be used, even if I add a video source. My A8 has a standard windscreen, so I test mounted the GPS receiver on the dash by the tax disc. Works fine in that location, picks up 6 satellites and gets a fix no problem so that's where I'll fix it I think. Still need to get the dashpod out to install the TMC and dash can connections, still don't know what size those weird screws are. They look like allen key bolts, so maybe a small allen key will work. I don't know if its my ears, but after doing the firmware upgrade the sound quality has improved and has more bass at all volume levels and actually sounds the same as the Symphony MK1. Before it sounded a little flat, even on the same settings.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 13th September 2012 at 06:02 PM. |
wondered if you could point me in the direction of where you got the firmware upgrade from Manny please?
cheers
Audi S8 2015, Daytona Grey |
Brian, the filename is AUDIFW2003.zip
Download here, http://www.lumpistefan.de/Audi/AUDIFW2003.zip Then basically extract the zip file to a folder. Then using Nero, Roxio or simillar create a standard data ISO CD (Not UDF format) and drag / drop the contents of the folder onto the CD. Burn at a slow speed (I used 4x) and make sure the session is closed. Restart the RNS-D holding down the flag and navigation buttons as you press power. Select Eject CDRom, and remove the navigation CD. Insert your FW disk, and at the bottom it should pop up next to CD version as 2003. below that are two options, select the top one, not the TMC one. System will check CD, restart, and update the headunit, System will restart again, and update the graphics software, System will restart again and tell you that the update was successful. Remove now ejected firmware CD, and put your nav disk back in. Press the right knob in to accept, don't do what I did and press return as prompted.
thanks for that, might give it a try if it improves the sound quality
cheers ![]()
The hex socket no 4. to undo the bolts on the instrument cluster and then it will pull forward....when you do put a towel over the top plastic part of the steering wheel as the instrument cluster might scratch it as you are fiddling to get the plugs off.
If the plugs havent been off will be some zip ties back there...patience and you will succeed. The two can wires you want to tap into are on the green plug. pin 21 for canbus low pin 22 for canbus high Good luck you are almost there!!!!!
01 Audi a8 fl sport - Grey, Bose, Glass Sunroof, S8 grill/mirror covers/wheels, Aftermarket Exhaust, very quick and lots of fun!!!!!....well I gave it one final push on the pedal to hear that v8 growl and then it was off to a new home..... 99 Audi a8 fl - Silver, Black alcantara seat/ S8 grill/side mirror, MFSW, Solar Sunroof, 17" Monoblocks (for that extra cushion of air), Rnsc, Bose.....great motorway cruiser....now gone to a new home 02 Final Edition S8 - Avus Silver, Extended Leather Pack III, Front & Rear Heated Seats, Servo, Blinds, Rear Seat Entairtainment with Playstation, Bose, Bi Xenons.....now gone to a new home 97 PF A8 4.2 quattro sport - Cashmere Grey, Servo, RNS E, Blinds, Bose, 20 Final Edition Alloys, LPG....sold sadly and will be missed 03 S4 V8 Saloon - Misano red, Manual, Milltek, Bose, Xenons, RNS E - Sold as of Feb 2012 |
Yep, almost there.
However, today I drove around town with the GPS aerial sitting on the dash. The RNS-D is seeing 8 satellites, so no problem there, however the map position completely wrong. The arrow is behind by a good 300 yards or more, and slightly to one side. Can you calibrate your position on the map using the crosshairs like you can on the VW MFD/MFD2?. I hope its not a bad GPS aerial, don't think it is as the compass display works well. Tomorrow, I am off to Hertfordshire from Dorset to finish the install and put the car back together. I'll put some pictures up of the install when finished of course, but I am sure you have all seen an A8 with RNS-D a hundred times before.
What happens when you park up does it eventually get the position right?
The satnav uses the inbuilt compass to work out which direct the car is heading and the speed signal from the car, the position is then corrected by the gps every minute or so. |
I believe that Gala is working, in that the map updates ok as I drive along, its just the positioning is way off. Even sitting in the car stationary it's never right.
I have the Gala wire on the cars loom on pin1, and the plug and play loom passes this to the correct pin on the 26 way connector. is there a way to check that Gala is working, by accessing a menu somewhere.
It takes a little while to calibrate the GALA etc.
Strictly speaking, the speed pulse signal off a factory fit unit comes direct from the ABS unit, and the pulses are far more frequent, and thus more accurate. The pulses from gala are less frequent, but will do the job ok. If you take an RNS-D from a factory fit car running ABS pulses to a retrofit running GALA pulses it will take maybe 10/15 mins of driving before they come into alignment. Until then, the GPS will keep correcting it, but the arrow will race off at the wrong speed. This is quite normal. They always constantly calibrate in the background to allow for tyre wear etc, so if you change wheels for example and have a slightly different circumference, it will sort itself out quite quickly with no intervention. Note as well that a factory fit unit should have a connection to the reversing signal so it knows when the pulses are going backwards. It keeps things more accurate if you're 3 point turning in a multistorey car park for example and want it to have some clue where you are when you hit the main road. Without it, the GPS will correct it when it gets a fix again. Incidently, the RNS-D can calibrate to the much slower speed of the GALA pulse (as can the VW/Seat/Skoa MFD)- The RNS-C cannot. Retrofitting an RNS-C requires the speed pulse hardwiring from the ABS controller in the Plenum chamber in the engine bay. And yes. I learned that the really hard way ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
